    printer moving very slow
    • Queevixundefined
      Queevix
      Hi there,
      So, I recently upgraded my prusa mk3s with a duet board. Everything seems okay, but when I slice a print with prusaslicer, and run the program, the printer moves ridiculously slow, in the range of 1-5mm/s. I used exactly the same settings as before (with the old board). Looking at the g-codes, everthing seems to be programmed with "normal" speeds.
      If I slice the same object in S3D, with similar settings, it works normally.
      Any ideas what could be causing this?
      greets,
      Alexander
      engikeneerundefined 1 Reply Last reply Reply Quote 0
      • engikeneerundefined
        engikeneer @Queevix
        @queevix what firmware flavour have you set PrusaSlicer to? By default it adds a set of new machine limits at the start of the gcode file for Marlin.
        Also Marlin uses different units to RRF (mm/s not mm/min)
        i3 clone with a bunch of mods
        Queevixundefined 1 Reply Last reply Reply Quote 0
        • Queevixundefined
          Queevix @engikeneer
          This post is deleted!
