Stuttering on arcs....
Hey all,
My printer was running fine and all of a sudden it starts jerking hard when making big arcs. The X and Y seem to be skipping steps and it wont trace the same arc twice correctly. I searched the forums and saw that for other people low jerk/acceleration parameters in the config file were to blame. I have accounted for this and I am still getting stuttering and skipping.
I have a HUNCH that it has something to do with how the slicer is breaking up large arcs into small line segments, but I thought that the processing capabilities of a duet2wifi would be plenty to mitigate this issue?
Seems like printing a large arc shouldnt be that big of a problem, but im at my wits end. Any help would be super appreciated!
BLV Cube 300 x 300
Duet2Wifi + Duex5
Triple independent Z
Latest firmware
Prusa slicer / Cura (same issue with both)Thanks
@parallax222 What firmware are you using and are you printing from SD card? You can try to exchange the microSD card (should be rated at least class 10) and check if that improves things.
@chrishamm Latest firmware.
I'm printing via dragging and dropping into the web interface, does that just upload to the SD card and print from that? cause if so, i may need to change the card..
@parallax222 Yes, that's right.
@chrishamm Will try that and report back. Thank you.
You can send M122 and copy paste the result here. We'd be looking for the hiccups value. It should be 0. If the step rate is exceeded this could cause stuttering.
Another possibility is having mesh compensation enabled and the Z jerk value being too low, but that would only cause stuttering, not positional errors.
The fact that it's not tracing the same arc twice makes me think it may be mechanical. Perhaps a loose grub screw on a motor pulley.
@chrishamm also, is there a way to run it NOT from the SD and how does that work?
@phaedrux
This is what it returned when I did M122=== Diagnostics ===
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.0 (2022-03-15 18:58:31) running on Duet WiFi 1.02 or later + DueX5
Board ID: 08DGM-956GU-DJ3SW-6JKDA-3S86L-KAMBG
Used output buffers: 3 of 24 (22 max)
Static ram: 23868
Dynamic ram: 75024 of which 40 recycled
Never used RAM 13148, free system stack 188 words
Tasks: NETWORK(ready,11.4%,232) HEAT(notifyWait,0.0%,316) Move(notifyWait,0.0%,364) DUEX(notifyWait,0.0%,24) MAIN(running,85.3%,410) IDLE(ready,3.3%,30), total 100.0%
Owned mutexes: WiFi(NETWORK)
Last reset 00:00:22 ago, cause: power up
Last software reset time unknown, reason: User, GCodes spinning, available RAM 13148, slot 2
Error status: 0x00
Step timer max interval 0
MCU temperature: min 22.9, current 26.6, max 26.8
Supply voltage: min 24.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
Events: 0 queued, 0 completed
Driver 0: standstill, SG min n/a
Driver 1: standstill, SG min n/a
Driver 2: standstill, SG min n/a
Driver 3: standstill, SG min n/a
Driver 4: standstill, SG min n/a
Driver 5: standstill, SG min n/a
Driver 6: standstill, SG min n/a
Driver 7: standstill, SG min n/a
Driver 8: standstill, SG min n/a
Driver 9: standstill, SG min n/a
Driver 10:
Driver 11:
Date/time: 2022-05-11 19:18:39
Cache data hit count 803251729
Slowest loop: 2.51ms; fastest: 0.19ms
=== Storage ===
Free file entries: 10
SD card longest read time 2.6ms, write time 0.0ms, max retries 0
DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
=== AuxDDARing ===
Heater 1 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty
=== DueX ===
Read count 1, 2.65 reads/min
=== Network ===
Slowest loop: 124.64ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address cc:50:e3:66:6e:ff
WiFi Vcc 3.35, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 26376
WiFi IP address 192.168.40.123
WiFi signal strength -33dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Was that after a print that had stutter?
@phaedrux yes
No mesh compensation in use and no hiccups. So there's that.
Two different slicers, so it's not that.I suspect it's mechanical.
@phaedrux Ok i tightened down the set screw on my stepper pulleys and made sure everything else in the housing looked good. Running again to see if that made any difference.
@phaedrux well im not having an issue now for some reason, so likely you guys were right and it was a mechanical issue. Thank you for your help!
