    configuring motor direction and endstops
    Gcode meta commands
    • 57buickundefined
      57buick
      Im building a ratrig with duet3 6hc.
      1. first question ive tried swapping motor directions and such but when i hit negative direction on Y it goes back instead of forward, X drives correctly negative to left, if I try changing the S1 or S0 on drives 3 and 4 I cant get them both moving towards front and left like normal on my other printeres?
      2. is the endstops(which might have something to do with it. The X endstop is setup to trigger minimum when it moves to left, the Y endstop is going to be mounted at rear of printer so that would be maximum at rear not minimum.
      my config files is below what am I getting wrong or not understanding?
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P3 S1 ; physical drive 0.3 goes forwards
      M569 P4 S1 ; physical drive 0.4 goes backwards
      M584 X3 Y4 Z0:1:2 E5 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M574 X1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io1.in
      M574 Y1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io0.in
      M558 P1 C"121.io0.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-20 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:400 Y15:400 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
      M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency
      M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out1 and set its frequency
      T0 ; select first tool
      • 57buickundefined
        57buick
        I guess maybe that just means my home point would be back left of machine? is that gonna cause any issues when it comes to slicing or anything like that? Ive just always had my previous printers home at the front left
          Phaedrux Moderator @57buick
          @57buick said in configuring motor direction and endstops:
          If the endstop is at the rear and the maxima, the endstop must be configured as M574 Y2 S1 P"io0.in"
          0,0 will stay as the front left.
          Also see the motor direction testing here: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_coreXY
          • 57buickundefined
            57buick
            @phaedrux said in configuring motor direction and endstops:
            ok got it, so now I hit Y home to test it and it triggered the switch and the LED turned on switch but motor did not stop. Also instructions say to go to the machine specific page to see the state of the switches but I cant find the switches anywhere in the duet web control that I can see?
            I also tried adding the ! infront of pin to invert it but that doesnt work.
            Does it have anything to do with my X switch not being hooked up yet?
              You can use M119 to test the state of the endstops.
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops
