    6HC power out
    • 57buickundefined
      57buick
      wiring up my printer, I have 24v coming into the "power in" AND into the "out 0 power in" and they both read 24v on my meter at those terminals but the "out 0" to the toolboard is only putting out 2.5v thus the toolboard wont power on properly whats going on, is there a jumper I need to change?
      57buickundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • 57buickundefined
        57buick @57buick
        I guess I figured out you dont run the toolboard power off of that terminal block on the 6hc? ran power directly from power supply and it works
          Phaedrux Moderator @57buick
          @57buick said in 6HC power out:
          out 0 power in
          This is the power input for Out0, which is intended for the high current heated bed output.
