    2 duet wifi boards Fan output directly to Endstop input
    • martin7404undefined
      martin7404
      Hi
      I s it OK to wire directly Fan output on Duet wifi to Enstop input on other duet wifi in order to use it as a trigger on the second
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
        I don't think so. The fan output would be the voltage of the PSU and the endstop would be expecting much lower. It would only be safe to do if you could ensure the endstop is only getting a low voltage.
        https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#operating-limits
        I think the endstops are max 8v tolerant on recent revisions. Though I'd personally want to keep it to 3v as it would normally expect for an endstop.
        martin7404undefined 1 Reply Last reply Reply Quote 0
          martin7404 @Phaedrux
          @phaedrux ```
          ;G4 S0.5
          G92 Z8
          G90 G1 Z1 F10000
          G1 Z-2 F100
          G1 Z-1 F6000
          G1 Z-3 F100
          G1 Z-2.5 F6000
          G1 Z-4 F100
          G1 Z-3.5 F6000
          G1 Z-5 F100
          G1 Z-4.5 F6000
          G1 Z-6 F100
          G1 Z-5.5 F6000
          G1 Z-7 F100
          G1 Z-6.5 F6000
          G1 Z-8 F100
          G1 Z-7.5 F6000
          G1 Z-9 F100
          G1 Z-8.5 F6000
          G1 Z-10 F100
          G1 Z-9.5 F6000
          G1 Z-11 F100
          G1 Z-10.5 F6000
          G1 Z-12 F100
          G1 Z-11.5 F6000
          G1 Z-13 F100
          ;G1 Z-12.5 F6000
          ;1 Z-13 F100
          G1 Z8 F5000
            I don't understand what I'm looking at there.
