Print quits, moves to home mid print
(I don't have much experience with troubleshooting 3D printers, so patience is appreciated.)
Our company recently bought and finished assembly of our Modix Big180X printer, using a Duet2/Duex5 expansion board, RepRap firmware 3.3. Calibration and test prints were done successfully, but we are running into issues with our first actual print - the print is stopping partway through the first layer with the printhead moving to the home position.
I'm connecting via the printer's access point and uploading the g-code files on the web interface. My first two attempts were using Prusaslicer, then I switched to Cura for the last. Each attempt got further, but stopped in that first layer. I'll attach the M122 response and a shared folder link with the gcode file.
Thanks for the help.
https://drive.google.com/drive/folders/14cWNyeeOmicOAmSK8EE4DOP6tQnf659p?usp=sharing
A single post for your issue is enough. Locked.
