    Pinda 2 dilemma
    1.5k
    • sinoleundefined
      sinole
      Hi
      I am trying to install pinda 2 on my printer I have configured the probe by reading multiple threads and studying caribou duet firmware. but I could not figure out how to and where to add my temperature compensation values. so far I found this thread which looks like the best way to do it, but looks like his way didn't work either. no one seemed to be able to configure the compensation part. can anyone help me with it and show me where caribou have entered this syntax.
      • fcwiltundefined
        fcwilt @sinole
        @sinole
        Are you talking about setting the probe Z Trigger Height parameter based on some temperature reading?
        Thanks.
        sinoleundefined 1 Reply Last reply Reply Quote 0
          You use G31. What part doesn't work?
          https://docs.duet3d.com/en/User_manual/Reference/Gcodes#g31-set-or-report-current-probe-status
          • sinoleundefined
            sinole @Phaedrux
            @phaedrux honestly I am still researching, haven't updated my printer yet. I'm using it. But all the treads that I red are hopeless.
            • sinoleundefined
              sinole @fcwilt
              @fcwilt yes exactly that.
              • fcwiltundefined
                fcwilt @sinole
                @sinole said in Pinda 2 dilemma:
                So what object do you wish to monitor the temperature of?
                • sinoleundefined
                  sinole @fcwilt
                  @fcwilt well it should be both bed and probe they both have compensation numbers. but if i have to only pick 1 would be the pinda probe. bed doesn't drift numbers as much.
                  • fcwiltundefined
                    fcwilt @sinole
                    Does the probe have a built-in temperature sensor of some sort?
                    • sinoleundefined
                      sinole @fcwilt
                      @fcwilt yes, its PINDA v2
                      fcwiltundefined oliofundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @sinole
                        So the sensor has a pair of wires for getting the signal from the distance sensor and a pair of wires for the temperature sensor.?
                        Are you using v3.3 or v3.4 of the Duet firmware?
                        • oliofundefined
                          oliof @sinole
                          @sinole @sinole you need to do four things
                          a) connect and configure the temperature sensor as normal (from another thread M308 S2 P"exp.thermistor_7" A"PINDA" Y"thermistor" T120000 B4725, your pin will likely be another).
                          and set the thermistor in G31 using the H parameter.
                          b) determine the trigger height at normal ambient temp, and set Z and ambient temperature in G31 using Z and S parameters
                          c) determine the trigger height at elevated temp. Then calculate the difference between trigger height at normal temperature and trigger height at elevated temperature and divide by the difference between ambient and elevated temperature. Use that result in the T parameter of the G31.
                          d) probe with temp compensation
                          Example:
                          a) You defined the temp sensor as the third sensor after the bed sensor (H0) and the print head sensor (H1), so your G31 gets H2. If you have multiple print heads or a chamber heater sensor, it could be another sensor number. read the temperature of this sensor, let's assume it's 20C and roughly matches bed and print head sensor when they are inactive. Let's assume your ambient temp is 20C
                          G31 H2 S20
                          b) Following the normal method to determine trigger height and get 2.6mm trigger height, and your probe is 30mm to the left of the nozzle and 5m in front of it.
                          G31 H2 S20 X-30 Y-5 Z2.6
                          c) Set your printer operating temps to something you'd normally probe at, like bed temp to 90 and print head temp to 250 (assuming an all metal hotend and printing ASA). Read the temperature of the probe thermistor. Let's assume for the example that this gets the ambient temp of the probe to 70 (it'll likely be lower but this makes it easier to do the maths in the example). Then determine the trigger distance at these settings. Let's assume for the example that the trigger distance is now 2.9mm. Then you divide the difference between trigger heights (2.9-2.6=0.3) by the difference in temp (70-20=50) so 0.3/50= 0.006. That's your T value.
                          G31 H2 S20 T0.006 X-30 Y-5 Z2.6
                          fcwiltundefined sinoleundefined 2 Replies Last reply Reply Quote 1
                          • fcwiltundefined
                            fcwilt @oliof
                            @oliof
                            Is the firmware feature specifically for the Pinda v2?
                            • sinoleundefined
                              sinole @oliof
                              @oliof thats alot to take in but thanks, I will work on it. I connected the probe to marlin printer and measure all of the offsets. it should be easy to just calculate T values. I assume with G31 H2 S20 T0.006 X-30 Y-5 Z2.6 you set up a linear pattern and you don't and to define more parameters am I correct?
                              • oliofundefined
                                oliof @sinole
                                @fcwilt no, it works for any temperature compensating setup. What I don't know is whether you could re use the bed thermistor for poor man's compensation.
                                With the high frequency probes like SuperPinda, temperature compensation is not as much required. I prefer those setups. In my experience, they drift no more than 0.02mm in typical 3d printer setups without a heated chamber. I'm not sure that you get much better results with temperature compensation unless you introduce lots of measurement tools and effort.
                                @sinole yes, compensation is linear.
                                fcwiltundefined sinoleundefined 2 Replies Last reply Reply Quote 0
                                • fcwiltundefined
                                  fcwilt @oliof
                                  @oliof said in Pinda 2 dilemma:
                                  Without knowing how a probe changes trigger height with temperature how can a fixed compensation scheme work?
                                  • sinoleundefined
                                    sinole @oliof
                                    @oliof you can build your own pinda v2. when you set it up its basically same thermistor as the 100k thermistor we used on beds. its just inside of the probe. I think it will still work even if you kapton tape a bed thermistor to any regular probe. its just very unsightly.
                                    • oliofundefined
                                      oliof
                                      @fcwilt said in Pinda 2 dilemma:
                                      You measure that as I outlined in my process, but instead of having your own thermistor you use the bed thermistor. It will be less precise, but may be sufficient. It would be worth to do as an experiment.
                                      • oliofundefined
                                        oliof @sinole
                                        @sinole Sure, but it's not required with a high resolution probe like SuperPINDA and the various probes that are the same or quite similar OEM product.
                                        • fcwiltundefined
                                          fcwilt @oliof
                                          I wasn't clear.
                                          The firmware uses a formula that makes an assumption of how the probe trigger height changes with temperature.
                                          Is it a given that all such inductive probe follow that formula?
                                          Thanks.
                                          • oliofundefined
                                            oliof @fcwilt
                                            @fcwilt no idea (-: Marlin uses a table with discrete values and interpolates between them.
                                            I'll leave the experimentation to others, since I'm happy with probes that are resistant to temperature changes.
                                            sinoleundefined 1 Reply Last reply Reply Quote 1
