    No voltage on Extruder Hot end?
    Using Duet Controllers
    584
      jay_s_uk
      @akds48 i'm not sure e0_temp is valid as a name. try e0temp. same for the other ones with a _
      Akds48undefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • Akds48undefined
        Akds48 @jay_s_uk
        @jay_s_uk
        It is a default firmware which i am using from 3D platform to operate the machine.
          droftarts administrators @jay_s_uk
          @jay_s_uk said in No voltage on Extruder Hot end?:
          It's fine:
          A pin name is a string of characters enclosed in double quotation marks. It is not case sensitive. All instances of _ and - characters are stripped from pin names before comparing them.
          https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3#pin-names
          • Akds48undefined
            Akds48
            @droftarts
            i have changed the thermistor but it is same again.
            could it be a VSSA fuse problem? as i have lower version of duet board and it has no fuse !
            i have the first one board which has not fuse for thermistor, bed or fan.
              droftarts administrators @Akds48
              @akds48 The large fuses are not the VSSA fuse, they are for heated bed, and fans/stepper motors/hot end heaters. From on of your earlier pictures, you have a v1.02 board, which means the VSSA fuse is resettable, so it shouldn't be causing a problem. (See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#pcb-revision-history)
              VSSA fuse problems were confined to v1.0 and v1.01 board, see https://docs.duet3d.com/en/User_manual/Troubleshooting/Parts#vssa-fuse
              I think you need to test the thermistor inputs. The easiest way to do this it to get a known-value resistor, and connect it directly to the thermistor pins, and see if the correct temperature is reported. I use these for testing:
