Issues after updating firmware for first time
Firmware installation
293
  • undefined
    OSCORP
    Hello!
    I haven't updated anything since I bought the printer back in early 2020 and now that I've updated all the way to the latest version of DuetWifi it's throwing all kinds of errors including not detecting my hotend or bed. Please if someone has any clue how to fix this that would be awesome. Thank you. Attached is my diagnostic. Let me know if additional info is needed. console.txt
    undefined 1 Reply Last reply 23 May 2022, 06:34 Reply Quote 0
    • undefined
      OSCORP
      Printer is a Troodon CoreXY
      • undefined
        jay_s_uk @OSCORP
        @oscorp did you update from RRF2 to RRF3? Your config needs updating for RRF3.
        Theres a config available here https://forum.duet3d.com/topic/16997/formbot-troodon-rrf-3-1-1-update?_=1653141263734
        undefined 1 Reply Last reply 23 May 2022, 06:50 Reply Quote 1
        • undefined
          OSCORP @jay_s_uk
          @jay_s_uk
          Hi Jay
          So I just input this config file and it's at least picking up the bed and hotend now! But it's giving me a Fan number 3 error code. Also I see this file is configured for the 300x300x400 troodon and I have to 400x400x500 one so not sure how much would have to be changed about that.
          undefined undefined 2 Replies Last reply 23 May 2022, 06:51 Reply Quote 0
          • undefined
            OSCORP @OSCORP
            @oscorp I'm also on the absolute latest version 3.4 for Reprap
            undefined 1 Reply Last reply 23 May 2022, 06:53 Reply Quote 0
            • undefined
              jay_s_uk @OSCORP
              @oscorp you'd have to change the M208 in config. and you'd have to adjust the M557 for a larger bed. Whats the error with the fan?
              Ideally though, you should try and understand what each line means rather than blindly copying someone elses config.
              undefined 1 Reply Last reply 23 May 2022, 06:57 Reply Quote 1
              • undefined
                OSCORP @OSCORP
                @oscorp and the printer screen is stuck on connecting, even after trying to swap baud rate so I can only control it through the Wi-Fi connection
                • undefined
                  OSCORP @jay_s_uk
                  @jay_s_uk
                  This is the fan error
                  M98 P"0:/macros/Preheat/preheat_PLA"
                  Error: Fan number 3 not found
                  Ok yea i'll have to work on swapping over everything to adjust for my bed size, thank you so much. Any ideas as to why the print screen is stuck on connecting now though?
                  undefined 1 Reply Last reply 23 May 2022, 06:59 Reply Quote 0
                  • undefined
                    jay_s_uk @OSCORP
                    @oscorp make sure your config has M575 P1 B57600 S1 in.
                    Theres no fan3 defined so thats why you get that error so you'll have to check the old config and see where it was plugged into etc and add it to the config.
                    undefined 1 Reply Last reply 23 May 2022, 07:06 Reply Quote 0
                    • undefined
                      OSCORP @jay_s_uk
                      @jay_s_uk
                      Ah perfect yea that fixed the issue with the screen stuck on connecting.
                      I have to head to bed for work tomorrow but I'm very glad to have most issues fixed.
                      Thanks a ton Jay, i'll be sure to ask you for any other help I need.
                      1 out of 10
