    Error en temperatura
    • Miguel7686undefined
      Miguel7686
      Hola a todos tengo el siguiente problema, tuve un corto circuito que me daño mi mother board la cambie , pero cuando inicio la maquina me marca temperatura de cama y de extrusor altas, en el análisis me indica lo siguiente:
      23/5/2022, 12:27:20: M122: === Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.03RC3 running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9P6M2-NW4SD-6JKF4-3SJ6N-TBQVK
      Used output buffers: 3 of 24 (6 max)
      Static ram: 25680
      Dynamic ram: 94136 of which 416 recycled
      Exception stack ram used: 320
      Never used ram: 10520
      Tasks: NETWORK(ready,784) HEAT(blocked,1236) DUEX(suspended,156) MAIN(running,3764) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:00:57 ago, cause: power up
      Last software reset time unknown, reason: User, spinning module GCodes, available RAM 10572 bytes (slot 3)
      Error status: 0
      Free file entries: 10
      MCU temperature: min 31.7, current 35.4, max 35.6
      Supply voltage: min 23.9, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 2: temperature-shutdown! short-to-ground standstill, SG min/max not available
      Driver 4: temperature-shutdown! short-to-ground standstill, SG min/max not available
      Driver 5: standstill, SG min/max not available
      Driver 6: standstill, SG min/max not available
      Driver 7: standstill, SG min/max not available
      Driver 8: standstill, SG min/max not available
      Driver 9: temperature-shutdown! short-to-ground standstill, SG min/max not available
      Date/time: 2022-05-23 12:27:19
      Cache data hit count 204368571
      Slowest loop: 3.83ms; fastest: 0.07ms
      Por lo que entiendo hay un corto en 3 drivers pero no ubico cuales son o a que estan conectados, me pueden ayudar a identificar correctamente la falla y solucionarla
        Phaedrux Moderator @Miguel7686
        @miguel7686 said in Error en temperatura:
        I had a short circuit that damaged my mother board, I changed it,
        Did you change the Duet board for a new one?
        Do you have a motor connected to that driver?
        Miguel7686undefined 2 Replies Last reply Reply Quote 0
          Miguel7686 @Phaedrux
          @phaedrux yes, I changed it and connected everything, but it gives me that error and it shows the temperature in bed and hotend in 2000
            @phaedrux I also put in the g code that I disable those drivers but the error continues
              Can you post your config.g file? What firmware version was the old board running?
              The firmware version reported version 2.03RC3 is quite old. Perhaps you were running a more recent version on the old board. Either way, you should update the firmware.
