    problems with input modeling using plugin
    • RODOKASundefined
      RODOKAS
      Friends, I need help using input modeling in duet 2 wifi 3.4.1
      I have the accelerometer installed and I speak the readings successfully using the imput shaping plugin 3.4.0 b1.
      after reading without input modeling, I apply some modeling to analyze the result, and they don't look good, I don't know if I'm doing something wrong or my mechanics are not good enough.
      I'll put images in the correct order, from the data collections made by the plugin.
      the interesting thing is that the plugin simulates the expected result with the input modeling, in these simulations the results seem very good, but when I collect data using the input modeling the actual results collected are not as good as the simulations.
      no shaper.jpg ![no shaper.jpg]
      simulating zvd
      ZVD
      simulating zvddd
      ZVDDD
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1rc1 (2022-05-03 09:34:00) running on Duet WiFi 1.02 or later
      Board ID: 0JD0M-9P6M2-NW4SS-6JKF6-3SJ6N-TBWVK
      Used output buffers: 1 of 26 (14 max)
      Static ram: 23868
      Dynamic ram: 77364 of which 12 recycled
      Never used RAM 9924, free system stack 124 words
      Tasks: NETWORK(ready,13.6%,230) ACCEL(notifyWait,0.2%,232) HEAT(notifyWait,0.0%,316) Move(notifyWait,0.0%,283) MAIN(running,86.0%,448) IDLE(ready,0.2%,30), total 100.0%
      Owned mutexes: WiFi(NETWORK) HTTP(MAIN)
      Last reset 00:09:15 ago, cause: power up
      Last software reset at 2022-05-20 11:14, reason: User, GCodes spinning, available RAM 12776, slot 2
      Error status: 0x10
      Aux0 errors 0,0,0
      Step timer max interval 0
      MCU temperature: min 20.1, current 30.2, max 30.4
      Supply voltage: min 24.5, current 24.6, max 24.8, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0
      Driver 1: standstill, SG min 0
      Driver 2: standstill, SG min 0
      Driver 3: standstill, SG min 0
      Driver 4: standstill, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2022-05-23 09:41:24
      Slowest loop: 56.88ms; fastest: 0.19ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 1.1ms, write time 248.2ms, max retries 0
      DMs created 83, segments created 38, maxWait 448960ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      Scheduled moves 20, completed 20, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
      === AuxDDARing ===
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is ready with "M122" in state(s) 0 0, running macro
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: ok
      === Network ===
      Slowest loop: 115.06ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      - WiFi -
      Network state is active
      WiFi firmware version 1.26
      WiFi MAC address 24:a1:60:2f:8d:12
      WiFi Vcc 3.40, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 26616
      WiFi IP address 192.168.1.109
      WiFi signal strength -47dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      After doing all the data collection, and inserting it in my config and I did a test print, I didn't see any difference, so something is really wrong
      please help me understand if i'm doing something wrong or there might be something wrong with my firmware.
      I'm using jerk of 300mm/min and accelerations of 3500mm/s2
      RODOKASundefined 1 Reply Last reply Reply Quote 0
      • RODOKASundefined
        RODOKAS @RODOKAS
        • mikeabuilderundefined
          mikeabuilder
          I've recently had a similar experience, so I'll be interested in seeing other responses here. I have a suspicion regarding the observations, but it's really mostly a guess that I have not taken time to check out on my printer.
          One of the checkboxes as you are about to collect data asks if data should be collected for the whole movement or only at the end. The default (I think) is that it collects the whole time. Input Shaping is applied at the beginning of a move (again, I think this is true) to try to counteract the "ringing" associated with the change from the previous move. If this is all true, then the vibrations you are looking for in the initial data collection and selection of IS options are those that happen after the end of the move. I'd really like to know if this is the correct waty to use the tool.
          I'm a novice with the new input shaping tool, but I did some successfully with the old tool. That tool showed you the acceleration profile and I could really see the ringing at the end of a move and the reduction of that ringing with IS applied (and on my parts, too). I'm not sure if the new tool will show the raw data or only shows the frequency analysis.
          Sorry this isn't a real answer. I'm learning too.
          • RODOKASundefined
            RODOKAS @mikeabuilder
            @mikeabuilder we are learning together, that's what the forum is for. let's wait for people with more experience to help us. I look forward to getting good results.
