    CNC Pause and Resume config files
    Gcode meta commands
    1.7k
    • Nightowlundefined
      Nightowl @OwenD
      This post is deleted!
      • Nightowlundefined
        Nightowl
        Well, I think I've got it, but there may be a tweak I could use to improve it, but as I've only got one spindle/tool this will probably do. This pause.g file works and saves the spindle speed to the defined variable:
        set global.savedSpindleSpeed = spindles[0].active
        echo "Spindle speed saved at " ^ {global.savedSpindleSpeed} ^ "RPM"
        G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} F2400 ; move the Z axis to a safe height
        G0 X273.5 Y560 ; move XY to a safe place
        M5 ; turn the spindle off
        ...and the resume.g file turns the spindle back on, although I think there are a few spurious lines in it now. I'll deal with that in the morning!
        Thanks @OwenD and @dc42 for your help with this 👍 👍
        • Nightowlundefined
          Nightowl
          • Nightowlundefined
            Nightowl
