    Failed to enable endstop configuring IR sensor
    • 57buickundefined
      57buick
      Im building a ratrig and I have the X and Y homing fine but after configuring the DC42 IR sensor it homes the X and Y then says "G28 failed to enable endstop"
      What am I doing wrong in the config here? I have it wired to a 1LC toolboard to 121.io0.in
      Here is my config:
      M550 P"ratrig500" ; set printer name
      M669 K1 ; select CoreXY mode
      ; Wait a moment for the CAN expansion boards to start
      G4 S1
      M552 P192.168.50.107 S1 ; enable network and acquire dynamic address via DHCP
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0.0 S0 ; physical drive 0.0 goes backwards
      M569 P0.1 S0 ; physical drive 0.1 goes backwards
      M569 P0.2 S0 ; physical drive 0.2 goes backwards
      M569 P3 S1 ; physical drive 0.3 goes forwards
      M569 P4 S1 ; physical drive 0.4 goes forwards
      M584 X4 Y3 Z0:1:2 E5 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X24000.00 Y24000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X10000.00 Y10000.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M906 X900 Y900 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      ;M84 S30 ; Set idle timeout
      M208 X500 Y500 Z500 S0 ; set axis maxima
      M574 X1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io1.in
      M574 Y2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io0.in
      M574 Z1 S2
      M558 P1 C"121.io0.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X-20 Y-10 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 X15:400 Y15:400 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create bed heater output on out1 and map it to sensor 0
      M143 H0 S150 ; set temperature limit for heater 0 to 150C
      M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
      M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency
      M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out1 and set its frequency
      ;accelerometer settings
      M955 P121.0 I14 ; set to toolboard address 121 and orientation of 14
      T0 ; select first tool
      57buickundefined 1 Reply Last reply Reply Quote 0
      • 57buickundefined
        57buick @57buick
        Also dose duet web control still supposed to show the Z probe sensor? Cus its not showing it anywhere on the web control to see what its reading?
        • 57buickundefined
          57buick @57buick
          Ok I figured out that because its connected to a toolboard it has to be set to P8 not P1 that made it show up in web control so I hit home all and it homes x and Y and then shows all 3 axis homes even though it never went and actually probed the Z?
          • fcwiltundefined
            fcwilt @57buick
            @57buick said in Failed to enable endstop configuring IR sensor:
            I don't think you have it all figured out.
            Being an IR sensor you should be able to jog the Z axis and when the sensor is close to the bed you should be able to see that state of the Z probe, as reported on the DWC, change.
            I always verify the individual pieces of hardware are working before trying to do things like "homeall".
            • 57buickundefined
              57buick @fcwilt
              @fcwilt said in Failed to enable endstop configuring IR sensor:
              Yea I just figured out changed the P1 to P8 made it show up in DWC now and manually putting a aluminum plate under it it changes from 1000 to zero when the led turns on so it is seeing it now. But it still shows homed after it homes the X and Y the Z also immeditately shows homed without actually going and probing the Z
              • fcwiltundefined
                fcwilt @57buick
                The triggered state is the 1000.
                So if you are seeing that when the sensor is NOT near the bed you need to invert the logic of the pin declaration you used for the Z probe.
                Add a ! character before the io0.in:
                M558 P1 C"121.io0.in" >= M558 P1 C"121.!io0.in"
                The reason is reports homed with out actually homing is because the firmware is seeing the sensor activated when it is not. So it thinks the homing was completed.
