    XY size compensation
    1295
    • fma
      fma last edited by
      Hi!
      I'm doing some tests with Slic3r 'XY size compensation param'.
      I printed a test part, with different holes sizes, and measured them: I have a constant offset, but it is different along X and Y!!! I should increase X by 0.2mm, but Y by only 0.1mm… But Slic3r only has 1 global value.
      Any idea what can cause that?
      BTW, it is the same for external values: I got 71.8mm for 72mm along X, and 41.9mm for 42mm along Y...
      Thanks,
      Frédéric
        What type of printer do you have?
        See also https://duet3d.com/wiki/G-code#M579:_Scale_Cartesian_axes.
        • fma
          fma last edited by
          It's a CoreXY.
          I can't use a scale factor, as it is really an offset. Same on a 5mm hole as on external 72x42mm rectangle (0.2/0.1mm)…
          I don't think it is a XY motor problem, but more an extrusion issue. But I can't see how it can be. Unless the nozzle hole is not circular?
          Frédéric
            If it's an offset rather than a scale factor, it is caused by backlash?
            • fma
              fma last edited by
              I noticed that my rectangular test part, with all the holes, was not orthogonal. Which could explain why the holes are not circular.
              So, I printed another test part, made of a 100x100mm set square, in order to measure and correct this: it is perfect!!!
              I'm puzzled…
              Frédéric
              • fma
                fma last edited by
                Sorry, I missed your post.
                I don't see any backlash in the carriage; belts are well tensioned. But I will check the hotend mount.
                Frédéric
                • fma
                  fma last edited by
                  Ok, the problem of non orthogonality appears when the part cools down; there are big holes on one side, small ones on the other side, so PLA retracts and twists the part. That's probably why my holes are not circular.
                  I will make another bigger print test part to check.
                  Frédéric
                  • DjDemonD
                    DjDemonD last edited by
                    Hi fma, one test for orthogonality which is quite robust with corexy is to print 5 squares, hollow only 2 layers tall, and maybe 2mm thick. Print one at each corner of the bed, and one in the centre. When they cool take them off and make sure they are all square and sit on top of one another perfectly. This test will show up slightly off square belt paths which exaggerate the effect in the corners rather than the centre.
                    www.precisionpiezo.co.uk
                    • fma
                      fma last edited by
                      Thanks for the advice. But I'm not sure to see how the squares should look like; do you have an example, on Thingiverse, for example?
                      Frédéric
                      • DjDemonD
                        Not on Thingiverse but this stl should show you what i mean:
                        https://1drv.ms/u/s!Apv79JfGbPIwg4EvUgYnxrRgAAxV5g
                        Each one has a unique notch, so once you take them off the printer you can work out which was which.
                        If the centre one is a parallelogram then the x and y axes are not orthogonal (belt tension unequal) if any of the corner squares are not square then the belt paths are not precisely 90 degrees from the x carriage to y carriages and y carriages to motors/pulleys.
                        • fma
                          fma last edited by
                          Thanks!
                          Frédéric
