How to use the rest of my SDcard space?
383
  • undefined
    imonsei
    Hi
    I purchased a ratrig vcore3 with the duet 3 board a while ago.
    It came with a nice 16gb SDcard, but it's only formattted to use little of that space, which leaves under 200MB for gcodes.
    Now I have received a job requiring a gcode file over 300MB
    Is there a way for me to make a new partition of the unused space, and have the Duet mount it to use as the gcodes folder?
    It corrently has the "boot" partition, and then an unreadable partition (from the viewpoint of reading the SDcard on windows10), and about .. 15 gigs of unused space.
    Or is there a smarter way about doing this?
    My firmware is - Firmware: RepRapFirmware for Duet 3 MB6HC 3.3 (2021-06-15)
    I have only been using the web interface to access the printer so far.
    undefined undefined 2 Replies Last reply 2 Jun 2022, 12:52 Reply Quote 0
    • undefined
      Stephen6309 @imonsei
      @imonsei Connect to the PI with PuTTY and log in
      Run sudo raspi-config
      Select Adavnced Options, then Expand File system
      That should fix it.
      undefined 2 Replies Last reply 2 Jun 2022, 13:06 Reply Quote 0
      • undefined
        imonsei @Stephen6309
        @stephen6309 I shall give it a try. thanks in advance.
        • undefined
          @stephen6309 Uh. I'm getting a "connection refused" error. when i SSH to the IP of the duet board.
          is that a setting i have to enable in a file on the SD-card?
          undefined 1 Reply Last reply 2 Jun 2022, 13:33 Reply Quote 0
          • undefined
            @imonsei All i know, is to put a blank text file called "ssh" in the boot directory. Don't know if it'll work on an already running Linux.
            To set up a new image: https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
            Don't forget to backup the macros and sys directory with DWC before making the new boot sd.
            undefined 1 Reply Last reply 2 Jun 2022, 13:50 Reply Quote 0
            • undefined
              @stephen6309 Dang it. I hoped it wouldn't be a big overhaul. Thanks for taking time out of your day to help me.
              • undefined
                gloomyandy @imonsei
                @imonsei Can we just check, are you using a raspberry Pi with this Duet board? Is the SD card you are talking about just plugged into the Duet board? It looks like @Stephen6309 thinks you have a rPi but I'm not sure if that is the case.
                undefined 1 Reply Last reply 2 Jun 2022, 14:03 Reply Quote 0
                • undefined
                  imonsei @gloomyandy
                  @gloomyandy I am using the duet 3 board with a sd card plugged directly into the board. there is no raspberry pi machine connected to it.
                  Sorry if I haven't been clear on that.
                  undefined 1 Reply Last reply 2 Jun 2022, 14:29 Reply Quote 0
                  • undefined
                    @imonsei I forgot to ask that. 🙄 Put the sd card in a card reader on the pc. Save the filament, gcodes, firmware, macros, sys, www directories to the pc, or use DWC to save them. Reformat the sd card with something like SDFormater, with the format size adjustment ON.
                    SD card layout: https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
                    Firmware & DWC releases:
                    https://github.com/Duet3D/RepRapFirmware/releases
                    undefined 2 Replies Last reply 2 Jun 2022, 14:51 Reply Quote 1
                    • undefined
                      @stephen6309 oh. I was nervous about the partition I couldn't read containing important files. Performing the reformat as we are speaking.
                      • undefined
                        @stephen6309 That worked a treat. Thank you both for your help 🙂 you are real human beans.
                        • undefined imonsei has marked this topic as solved 2 Jun 2022, 15:05
                        2 out of 11
