    Using endstop for DC motor
    Using Duet Controllers
    • adistrundefined
      adistr
      I connect dc motor to my duet 2 wifi board - through a driver, an external power source and it works great.
      The question I have is how can I use one of my endstop switches to stop a dc motor (like a stepper motor) when the endstop switch is pressed?
      Or other option -
      how can I catch an event of "endstop pressed" and after that event execute specific command?
      Thanks,
      Adi
      alankilianundefined 1 Reply Last reply Reply Quote 0
      • alankilianundefined
        alankilian @adistr
        @adistr THIS POST talks about using an endstop switch as a "trigger" and then using the M581 command to configure the results.
        Basically, you would use M581 to connect your endstop switch input to trigger #2 and when the endstop was hit, the macro sys/trigger2.g would be executed.
        adistrundefined 1 Reply Last reply Reply Quote 2
        • adistrundefined
          adistr @alankilian
          @alankilian
          I appreciate your response very much.
          I connect the end stop switch to Y (without a motor)
          • In addition, I added to sys trigger1.g file that contains the following command: M42 P7 S0.
            I also add this line at the end of the config file -
            M581 T1 Y S1.
          Why is the trigger not executed and the DC motor continues to run?
          Additionally, I have tried adding M300 in the trigger file to understand if the file is executed when the end stop is pressed, but the beep is not working.
          What am I doing wrong? Any suggestions?
          Thanks,
          Adi
          alankilianundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            alankilian @adistr
            @adistr
            You have to use a trigger number 2 or greater as in my example.
            Trigger number 0 causes an emergency stop as if M112 had been received. Trigger number 1 causes the print to be paused as if M25 had been received. Any trigger number # greater than 1 causes the macro file sys/trigger#.g to be executed.
            You can test your trigger macro by typing this in the console
            M98 P"trigger2.g"
            If you still have problems, post your complete config.g and your complete trigger2.g and we'll take a look.
              Phaedrux Moderator @adistr
              @adistr said in Using endstop for DC motor:
              M581 T1 Y S1.
              This looks like syntax for RRF2. Surely you are on RRF3.4 now which is far more felxible?
              https://docs.duet3d.com/User_manual/Reference/Gcodes#m581-configure-external-trigger
