    Wiring Servo
    609
    • 2500ccmundefined
      2500ccm
      i need a Servo for my Tool0. Problem is all PWM Pins are used on the Duet2 Ethernet and the Duex5. On PWM5 is the Bltouch. Where i can get a Pwm Signal for the Servo. I thought Fan8 can have a Pwm Signal, but it is not possible.
      Other idea is to use the servo and the bltouch both on pwm5 and made there powersupply switchable.
      Maybe have someone a better solution?
      Thanks Mo
      DIY-O-Sphereundefined 1 Reply Last reply Reply Quote 0
        Do you have a free heater pin?
        • 2500ccmundefined
          2500ccm
          No. This would be the easiest way...
            What pins do you have free? Just fan8?
            • 2500ccmundefined
              2500ccm
              Sorry for the late reply. I had a lot of work to do.
              Free are Fan 1 and 8. Pwm 1-4 have free sockets, but the heater sockets are used. Pwm5 have a bltouch connected.
              Maybe use Fan 1 and 8 for switching the gnd or 5v of the servo and bltouch on/off. Then use the same pwm signal of PWM5? Is this possible?
              Bltouch and the servo for toolchange is not often used.
              • DIY-O-Sphereundefined
                DIY-O-Sphere @2500ccm
                @2500ccm
                An Sx1509+External Mosfet would be an option
                (UTC+1)
                  dc42 administrators @2500ccm
                  @2500ccm you could use the FAN1- pin to control the servo if you connect a pullup resistor between it and the +5V supply to the servo. You will need to invert the output in the M950 command.
                  2500ccmundefined 1 Reply Last reply Reply Quote 0
                  • 2500ccmundefined
                    2500ccm @dc42
                    Thanks for all replies.
                    I will do it like @dc42 dc42 said. Which one do you prefere?
                    • 2500ccmundefined
                      2500ccm
                      Now i got time to take this task on my todo list and installed a 3.9kohm resistor between 5v supply and signal. The 5v supply is external. I connected ground and 5v at external supply and signal at fan1-.
                      Commands are:
                      M950 S1 C"!fan1"
                      M280 P1 S125
                      Nothing happend. After that i googled and found in the duet wiki a part about external pullup resistor. 10kohm is recommend.
                      Is this my failure?
                      Thanks for reply
                      Moritz
                        @2500ccm the value of the pullup resistor is not critical. Did you connect the ground of your external 5V PSU to Duet ground?
                        2500ccmundefined 1 Reply Last reply Reply Quote 1
                        • 2500ccmundefined
                          2500ccm @dc42
                          @dc42 Sorry for my late reply. After i connected ground it worked well! Thanks alot
