    First time cura and my problem
    368
    • jamaicarastaundefined
      jamaicarasta
      Hey guys, good morning from Germany. I would like to try Cura once. Have loaded it now, inserted my normal start and end codes as in superslicer and created a Voron. If I now slice and simulate this file, I get an error in the console. But he still simulates to the end.
      M37 P"0:/gcodes/bbbbbbbbbbb.gcode"
      Simulating print of file 0:/gcodes/bbbbbbbbbbb.gcode
      Error: Bad command: mperature]
      Error: in GCode file line 19 column 11: M109: expected number after 'r'
      Can someone tell me what could be the reason? an approach? Thanks in advance
      dc42undefined Stephen6309undefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @jamaicarasta
        @jamaicarasta my guess is that the GCode file contains a line that is meant to be a comment but lacks the semicolon at the start.
        jamaicarastaundefined 3 Replies Last reply Reply Quote 0
          jamaicarasta @dc42
          @dc42 Yes, 2 lines ;G32 and ;G1 X175 Y175 F18000 it was dir testingโ€ฆ In my start code
            jamaicarasta @dc42
            @dc42 i check that. without semikolon ist the same issue
            • Stephen6309undefined
              Stephen6309 @jamaicarasta
              @jamaicarasta You have an error in your start gcode:
              It appears the error in the line that sets the hotend temperat.ure. The mperature] is missing the part of the line.
              jamaicarastaundefined 1 Reply Last reply Reply Quote 0
                jamaicarasta @Stephen6309
                @stephen6309 but it works in superslicer perfect.
                It is different in Cura?
                Stephen6309undefined 1 Reply Last reply Reply Quote 0
                  @jamaicarasta You'll have to check the documetation, Cura may use different variable names.
                  Make sure it was copied fully.
                    @stephen6309 I will check that, thanks
                      jamaicarasta @dc42
                      @dc42 I solved the problem. Deleted the M190 and M109 in the start code ๐Ÿ‘ŒFirst temp bed and layer.
                        @jamaicarasta I use this SuperSlicer start gcode, thought it would help.
                        T-1                                         ; deselect tool, tool to standby temp
                        M1000 Q"[filament_type]" ;custom M gcode to set G31 Z offset for filament_type
                        G10 P0 S[first_layer_temperature] R140
                        M190 S[first_layer_bed_temperature]
                        M98 P"/macros/EnableHoming"
                        G32                                        ; bed calibration
                        G29                                       ; bed mesh
                        M98 P"/macros/DisableHoming"
                        T0                                          ; select T0 and go to active temp
                        M116                                    ; wait for temp
                        G1 E6                                    ; extrude a bit
                        /sys/M1000.g, sets the G31 Z offset and retraction:
                        ; M1000 Q"[filament_type]"
                        echo "Set G31 Z offset for ",param.Q
                        if param.Q == "PETG"
                        	M98 P"/sys/PETGOffset.g"
                        elif param.Q == "PLA"
                        	M98 P"/sys/PLAOffset.g"
                        elif param.Q == "TPU"
                        	M98 P"/sys/TPUOffset.g"
                        jamaicarastaundefined 2 Replies Last reply Reply Quote 0
                          @stephen6309 thanks, i solved the problem. Deleted the M190 and M109 in the start code ๐Ÿ‘ŒFirst temp bed and layer.
                            @stephen6309 and my first print with cura was better than superslicer ๐Ÿ‘Œ
                            I will try it tomorrow with a few prints.
                            greetings from germany
