    Print wtih 2 Colling fans
    233
    • Mangelliundefined
      Mangelli
      I have a Duet Maestro and configure my Fans on Pin0, Pin1 and Pin2.
      I have 2 colling fans(0 and 2) and one hotend fan(1). When I start to print, just the PIN 2 and PIN 1 start.
      I looked a lot and try some configs but none seems to work.
      The Tool move both fans at same time but just start one.
      Follow the config.
      M106 P0 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M106 P1 S1 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
      M106 P2 S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M563 P0 S"Hotend" D0 H1 F0:2 ; define tool 0
        Can you try swapping the wire plugs for fan 0 and 2 and see if it's the port that isn't working or the fan.
        Mangelliundefined 1 Reply Last reply Reply Quote 0
        • Mangelliundefined
          Mangelli @Phaedrux
          @phaedrux said in Print wtih 2 Colling fans:
          Hey, both Fans is working. They just don`t start together. If I move the Tool fan, both fans move together.
            What fan commands does your slicer send to start the fans?
            • Mangelliundefined
              Mangelli @Phaedrux
              Sorry for the Delay.
              Follow the g-code.
              M106 S255 P2
              I don`t know why it is like this.
                Phaedrux Moderator @Mangelli
                @mangelli said in Print wtih 2 Colling fans:
                M106 S255 P2
                Your slicer probably has a setting to tell it which fan to target. If you have it leave off the P value, the duet will just use the fans assigned to the tool.
                Mangelliundefined 2 Replies Last reply Reply Quote 0
                • Mangelliundefined
                  Mangelli @Phaedrux
                  After you asked me to look at the settings, I decided to look in CURA. In the cura settings (Cooling Fan Number) it was 2. I changed it to 0 and now the code sent is just "M106 P255" and the 2 fans are turning on.
                  • Mangelliundefined
                    Mangelli @Phaedrux
                    M106 S255 P2
                    Yes, the problem was the Slicer`s settings. Thank you so much for your help.
                    I was looking in the wrong place all the time.
