    6HC -> external stepper with CANopen instead of stp/dir/en ?
    Using Duet Controllers
    • lbtqsbundefined
      lbtqsb
      was wondering if external steppers that feature CANopen are compatible with the duet-environment, in my case a 6HC board, where it would be cheaper to get a big CANopen stepper (in my case tinkering with the idea to get one from nanotec https://en.nanotec.com/knowledge-base-article/canopen-motors-controllers) to save on the 1HC stp/dir/en-breakout-board...
      Any suggestions anyone?
      Best
      L
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @lbtqsb
        @lbtqsb CANopen is not supported
          https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection
          CAN-FD only
            dc42 administrators @lbtqsb
            @lbtqsb when we started researching the use of CAN bus to communicate with expansion boards, I quickly established that CAN-Open was much too slow to support the moves/second rate needed by 3D printers and similar machines when executing curved outlines. In fact, plain CAN didn't have enough bandwidth even without the overheads of a heavyweight protocol such as CAN-Open. This is why we reluctantly gave up on the idea of supporting CAN-connected expansion boards on Duet 2, whose processor supports CAN but not CAN-FD.
            Since we implemented the CAN support in RRF, a variant of CAN-Open that uses CAN-FD has been defined. I have not investigated whether it might be possible to support the movement rates needed for 3D printing; but I think it unlikely. The requirement is to support around 1000 moves/second to multiple CAN-connected boards, with each move containing details of the movement profile, any pressure advance applied, and any input shaping applied.
            lbtqsbundefined 1 Reply Last reply Reply Quote 1
            • lbtqsbundefined
              lbtqsb @dc42
              Thanks so much!
              That clearified my decision which way to go down the road on the y I was contemplating... 🙂 So it will be 2pcs 1HC to try out 48Volt with lot´s of Amp 😉 Thanks!
