    Error in Docs for M591
    Filament Monitor
    • tfjieldundefined
      tfjield
      Re: filament-error#.g usage help? Avoid pausing on sensorerror?
      I think there is an error in the docs for M591. It currently says:
      In RRF 3.4 and later, the action on a filament error is to:
      • run filament-error#.g if available, where # is the extruder number
      • failing that run filament-error.g if available
      But the upgrade notes say:
      • The handling of filament errors have changed. When a filament error occurs, an event is created. To handle the event, RRF runs macro file filament-error.g without appending the extruder number to the file name and without pausing the print first. The extruder number is passed as param.D along with some other parameters. If filament-error.g is not found then the print is paused (running pause.g) and the error is reported.
      I've looked through the code and I don't think filament-error#.g is ever called.
        dc42 administrators @tfjield
        @tfjield thanks for pointing this out. I have amended the documentation.
        tfjieldundefined ComedianTF2undefined 2 Replies Last reply Reply Quote 2
        • tfjieldundefined
          tfjield @dc42
          @dc42 Thank you!
          • ComedianTF2undefined
            ComedianTF2 @dc42
            @dc42 Do you have an example of the param.D being used?
            • tfjieldundefined
              tfjield
              @comediantf2
              This is what I put in filament-error.g so that it would work with both 3.3 and 3.4+:
              M25				; first, pause the print as pre-RRF 3.3 did
              if {param.D == 0}		; now call the right pre-RRF 3.4 subroutines.
              	M98 P"filament-error0.g"
              elif {param.D == 1}
              	M98 P"filament-error1.g"
