    duet 2 wifi not extruding tool 0
    • Cavemanundefined
      Caveman
      New duet wifi is not extruding tool 0 in anycubic delta linear plus.
      config (11).g
      Any idea what I have done wrong here?
        droftarts administrators @Caveman
        @caveman Are you activating Tool 0? There is no T0 in your config.g. See https://docs.duet3d.com/en/How_to_guides/Commissioning#h-5-check-heater-functionality
        Note RRF does not allow extrusion if the tool temperature is below 160C. If you have no filament loaded and want to just test motor movement, first send T0 to activate the tool, then send M302 P1 to allow cold extrusion.
        If it still doesn't work, send M98 P"config.g", and M115 for the firmware version, and post the response here. Also check that your firmware version and DWC version are the same.
