    error invalid P parameter on start up
    • A Former User?
      A Former User
      reprap 3.4 duet 2 wifi with paneldue v3 all in one 5”, on start upPanelDue showing massage: error invalid P parameter.
      How to see which P parameter is wrong?
      Thanks!
      My config.g
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.5 on Thu Oct 28 2021 15:34:12 GMT+0200 (Central European Summer Time)
      M550 P"VORON" ; set printer name
      M669 K2 X1:0:1 Y0:1:0 Z1:0:-1 ; select CoreXZ mode
      M552 S1. ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z80.00 E427.45 ; set steps per mm
      M566 X600.00 Y600.00 Z600.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z30000.00 E3600.00 ; set maximum speeds (mm/min)
      M201 X3000.00 Y3000.00 Z3000.00 E7000.00 ; set accelerations (mm/s^2)
      M906 X1500 Y1500 Z1500 E600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X0 Y-215 Z-3.0 S1 ; set axis minima
      M208 X250 Y210 Z230 S0 ; set axis maxima
      M574 X2 S1 P"^xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin ^xstop
      M574 Y2 S1 P"^ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ^ystop
      M574 Z1 S2 P5 ; configure Z-probe endstop for low end on Z
      M558 P5 C"zprobe.in" H9 F400 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y25 Z1.76
      ; set Z probe trigger value, offset and trigger height
      M557 X25:270 Y10:210 S100 ; define mesh grid
      M308 S10 Y"mcu-temp" A"MCU"
      M308 S11 Y"drivers" A"Duet stepper drivers"
      M950 F2 C"fan2" Q500
      M106 P2 T45:65 H10:11
      M593 P"zvddd" F40.0 ; use ZVDDD input shaping to cancel ringing at 40.0Hz
      G92 S0
      M572 D0 S0.025 ; Pressure advance
        jay_s_uk @A Former User
        @voronswcroatia send M98 P"config.g" in DWC. That might give you more of an indication whats wrong
        A Former User? 2 Replies Last reply Reply Quote 0
        • A Former User?
          A Former User @jay_s_uk
          @jay_s_uk said in error invalid P parameter on start up:
          M98 P"config.g"
          This is what’s command put out
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Invalid use of P parameter
          My config.g
          G92 S0
          • A Former User?
            @jay_s_uk
            By the way thanks for quick replay
            I see that I put “.” After S1
            Changed that, still same error massage...
              @voronswcroatia it could be that M574 line for Z. Just comment it out
              • A Former User?
                @jay_s_uk thanks!!!!
                It’s solve the error...
                M98 P"config.g"
                ;M574 Z1 S2 P5 ; configure Z-probe endstop for low end on Z
                • dc42undefined dc42 marked this topic as a question
