    Prusa slicer speed not following my settings
    3D Printing General Chat
    1.4k
    • mikeabuilderundefined
      mikeabuilder
      I've stumped myself on this. I was making some simple shapes to use for observing and selecting good settings for max speed, accel, jerk. I made 1 layer thick circles and squares with a width equal to the extrusion so I would get unfilled circles and squares as output from the slicer.
      Oddly, the slicer is not using my speed settings when setting the speed in the sliced gcode file. I hoping someone can point to somewhere I'm being stupid. The square is the simplest of the files. I set a speed of 200mm/sec and get a speed of 50mm/sec on my gcode file. I'm attaching my 3MF (remove the .bin) file and the gcode my slicer generated.
      50mm square.3mf.bin
      50mm square.gcode
      Stephen6309undefined 1 Reply Last reply Reply Quote 0
        Probably your min layer time setting?
        • Stephen6309undefined
          Stephen6309 @mikeabuilder
          @mikeabuilder CheckPrinter Settings->Machine Limits->How to apply limits.
          If set to Emit to GCode, the PrusaSlicer will set them in the sliced gcode. The other two won't do that.
            mikeabuilder
            @Phaedrux - SOLVED! I didn't even know there was a setting for that.
