    How do I change the max temperature for my hotends?
    • silver1882undefined
      silver1882
      I have this in the config.g but it still will not let me go that hot.
      M143 H1 S290
        dc42 administrators @silver1882
        @silver1882 some suggestions:
        1. Run M143 H1 with no additional parameters to see if the command was accepted.
        2. Check that the M143 H1 command in config.g is later in the file that the M950 H1 command that creates the heater.
        3. Run M98 P"config.g" to check for errors in config.g.
        silver1882undefined 1 Reply Last reply Reply Quote 0
          silver1882 @dc42
          @dc42 said in How do I change the max temperature for my hotends?:
          M143 H1
          Thanks for the suggestions. I figured the problem out I have to set the temp 1c higher than what I want my max to be in my config.g file.
