    Unable to connect to WIFI
    • darbyad85undefined
      darbyad85
      I have entered command M552 and entered the login details for my router
      #I have also confirmed it is a remembered device
      when i enter the next step M552 S0 - from YAT i just get ok and on the Panel it just continues with
      WiFi reported error: no known networks found
      WiFi module is idle
      WIFI reported error: no known networks found
      WIFI module is idle
      I have tried disconnecting WIFI and reconnecting
      What i am expecting to see is that its connected the WIFI and it gives me an IP address so i can connect to DWC
      Thanks in advance
        darbyad85
        So i have been trouble shooting all day
        My WIFI and hub at home both run 5GZ - could this be the issue
        I have also connected to both our phones and get the following
        Remembered networks:
        TNCAPF2FD81 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
        Three556370 IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        Bens iPhone (3) IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        Adele IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        It connects but i still cannot connect to wifi - the fact that i see all 0's make me think its not connected to anyone of them
          The Duet can only connect to 2.4ghz networks. Most wifi routers have the option for both 2.4ghz and 5ghz networks.
          darbyad85undefined 1 Reply Last reply Reply Quote 0
            darbyad85 @Phaedrux
            @phaedrux thanks... managed to sort this now! Home wifi was 2.4 and its now connected... trouble I think was registering it on the diplay board rather than YAT
              Good to hear. Let us know if you have any other snags.
