    Update SBD duet3 failed to doenload packages
    Firmware installation
    • Tinchusundefined
      Tinchus
      Hello. I did an udate to the duet3 board, in SBC mode.
      In the ssh console I use instructions from https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup
      sudo apt-get update >>>>> This commands ends with this:
      W: Failed to fetch https://pkg.duet3d.com/dists/stable/InRelease Could not connect to pkg.duet3d.com:443 (134.209.94.168), connection timed out
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      The executing sudo apt-get upgrade finishes OK, but the firmware and DWC seems to not bhave been updated because I still has 3.3 version (I m suposed to update to 3.4)
      What Im doing wrong?
        jay_s_uk @Tinchus
        @tinchus you would also need sudo apt upgrade
        The easiest is just to send this command which combines the two sudo apt update && sudo apt upgrade -y
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @jay_s_uk
          @jay_s_uk Sorry, I have updated the original post. I did that command. And that command finishes OK without error, but firware nor DWC has been updated
            Can you post the results of sending M122?
            Did DSF update?
            Are you still getting any errors?
