Can't Home With PanelDue
I home my printer just fine from DWC. But on the PanelDue I get " Error: homeing file homex.g not found" same for homey.g and homeall.g. But if I go to DWC it works fine. Crazy thing is it just started happening. Its a new printer build and the PD was fine then seemingly out of the blue this starts happening. Thoughts? One observation if the PD is displaying my macro files. then homing will work. but if it sitting there and the right side of the PD is blank its going to fail. is it having some type of problem parsing the macro name
Auto Z offset
(the only file there right now) Inquiring minds want to know.PD is a Fysetc 5" v3.0 running firmware 3.4.0
Other useful info:m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.4.1 (2022-06-01 21:09:01) running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J1FL-3S86M-9TBLT Used output buffers: 1 of 40 (17 max) === RTOS === Static ram: 151000 Dynamic ram: 66712 of which 144 recycled Never used RAM 132816, free system stack 202 words Tasks: SBC(ready,1.2%,458) HEAT(notifyWait,0.0%,353) Move(notifyWait,0.0%,352) CanReceiv(notifyWait,0.0%,797) CanSender(notifyWait,0.0%,374) CanClock(delaying,0.0%,351) TMC(notifyWait,7.6%,94) MAIN(running,84.4%,923) IDLE(ready,6.8%,30), total 100.0% Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:00:09 ago, cause: software Last software reset at 2022-06-15 20:05, reason: User, GCodes spinning, available RAM 132456, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043c000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 164 MCU temperature: min 39.4, current 39.7, max 39.9 Supply voltage: min 24.1, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.2, current 12.3, max 12.3, under voltage events: 0 Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0, mspos 856, reads 51706, writes 15 timeouts 0 Driver 1: standstill, SG min 0, mspos 184, reads 51706, writes 15 timeouts 0 Driver 2: standstill, SG min 0, mspos 856, reads 51706, writes 15 timeouts 0 Driver 3: standstill, SG min 0, mspos 184, reads 51706, writes 15 timeouts 0 Driver 4: standstill, SG min 0, mspos 872, reads 51706, writes 15 timeouts 0 Driver 5: standstill, SG min 0, mspos 552, reads 51707, writes 15 timeouts 0 Date/time: 2022-06-15 20:05:43 Slowest loop: 1.20ms; fastest: 0.05ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Filament sensors === Extruder 0 sensor: no data received === CAN === Messages queued 77, received 125, lost 0, boc 0 Longest wait 3ms for reply type 6053, peak Tx sync delay 5, free buffers 50 (min 49), ts 47/46/0 Tx timeouts 0,0,0,0,0,0 === SBC interface === Transfer state: 5, failed transfers: 0, checksum errors: 0 RX/TX seq numbers: 1667/1667 SPI underruns 0, overruns 0 State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b880 Buffer RX/TX: 0/0-0, open files: 0 === Duet Control Server === Duet Control Server v3.4.1 Code buffer space: 4096 Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0 Full transfers per second: 212.33, max time between full transfers: 40.8ms, max pin wait times: 40.4ms/13.2ms Codes per second: 9.92 Maximum length of RX/TX data transfers: 3080/940
