Duet 2 Killerbee CNC with OpenBuilds INTERFACE
CNC
  • undefined
    Novastorm
    Does anyone knows if it is possible to use then OpenBuilds CNC Interface with an Duet 2 Ethernet Controller?
    Connection ist etablished over UART:
    https://docs.openbuilds.com/doku.php?id=docs:interface:connect-generic
    The Duet 2 supports UART on the PanelDue Connector but does the Duet 2 support Gbrl 1.1?
    Using converted UM2+ Dual-Extrusion
    undefined 1 Reply Last reply 19 Jun 2022, 08:15 Reply Quote 0
    • undefined
      jay_s_uk @Novastorm
      @novastorm this won't work unless you can change the firmware on the controller to support the way RRF likes it's commands
      undefined 1 Reply Last reply 23 Jun 2022, 15:13 Reply Quote 0
      • undefined
        Novastorm @jay_s_uk
        @jay_s_uk
        Thank you!
        Maybe someone at Openbuidls can tell me, if it is possible to build a Custom Firmware for the Interface.
        undefined 1 Reply Last reply 23 Jun 2022, 18:51 Reply Quote 0
        • undefined
          Sindarius @Novastorm
          @novastorm Last I remember the OpenBuilds Interface was not open source so there's no clean way to convert it to use RRF.
          1 out of 4
