    Incorrect extrusion amount on slow and/or small axis moves
    2.4k
    • ardenpmundefined
      ardenpm @gloomyandy
      @gloomyandy No, because I don't want to limit the E axis to that feedrate, I want it to run at the specified rate but the B axis much slower than normal. Without this the E axis will run up to its limit to try and sync with the short B axis move time. Without doing this I need to slow down the E axis too much.
      deckingmanundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
      • deckingmanundefined
        deckingman @ardenpm
        @ardenpm I see what you are doing but why not keep it simple and just set M203 E300 (to set say 5mm/sec), then do the G1 move and use M203 E3600 (to restore the feedrate value)?
        ardenpmundefined 1 Reply Last reply Reply Quote 0
        • ardenpmundefined
          ardenpm @deckingman
          @deckingman Yes, that’s true I could also do that. I’ll need to use the object model to find the current tool to apply it to the right extruder motor so that should be possible. I haven’t confirmed that limiting the extruder instead of the movement axis has the same affect but I would assume it must. I would still set the limit of the extruder though to the feedrate I actually want since otherwise it would just always run at 300 (I have multiple steps at different feedrates in my case). But limiting the extruder is simpler and shouldn’t hit the other minimum speed issue. I’ll definitely give that a go.
            deckingman @ardenpm
            @ardenpm You could by-pass using the object model by setting the maximum extrusion rate for all extruders. So for example M203 E300:300:300:300 and then put them all back with M203 E3600:3600:3600:3600.
            • ardenpmundefined
              ardenpm @deckingman
              @deckingman I prefer to restore the feedrates to their previous value rather than a hard coded value when done so if I change my configuration I don't need to hunt for values in my different macros. However that should be pretty straight forward, something like this.
              var defaultSpeed0 = move.extruders[0].speed
              var defaultSpeed1 = move.extruders[1].speed
              var defaultSpeed2 = move.extruders[2].speed
              var defaultSpeed3 = move.extruders[3].speed
              M203 E{param.F}
              G1 B{param.B} E{param.B} F{param.F}
              M203 E{var.defaultSpeed0}:{var.defaultSpeed1}:{var.defaultSpeed2}:{var.defaultSpeed3}
              Which is definitely still simpler than the first macro I had there. Definitely lots of ways to skin this particular cat.
              • fcwiltundefined
                fcwilt @ardenpm
                @ardenpm said in Incorrect extrusion amount on slow and/or small axis moves:
                If B and E are not kept in sync how do you see that working? Would E just continue to run after B is done?
                Thanks.
                • ardenpmundefined
                  ardenpm @fcwilt
                  @fcwilt That's actually the issue, it does attempt to keep them in sync and it thinks on the extruder side it has enough headroom to run it all the way up to my configured maximum speed of 3600mm/m for extruders, where as my extruders can handle more like only 300mm/m without skipping.
                  The reason the extruders are configured to allow a speed much higher than they can actually extrude is because of retractions, which happen at a much faster speed than extrusions. So by limiting the extruder temporarily to the limit for practical extrusion it should force the movement axis to slow down further to say in sync.
                  • fcwiltundefined
                    fcwilt @ardenpm
                    Does your slicer have a place you can enter code during a retraction? Some of them do.
                    That would solve the speed problem as you could set the extruder speed to the max for extrusion and in the retraction handler up the speed during retraction and then put it back to normal.
                    tfjieldundefined ardenpmundefined 2 Replies Last reply Reply Quote 0
                    • tfjieldundefined
                      tfjield @fcwilt
                      @fcwilt Or he could use firmware retraction.
                      • fcwiltundefined
                        fcwilt @tfjield
                        @tfjield said in Incorrect extrusion amount on slow and/or small axis moves:
                        How does that handle the speed issue?
                        Thanks.
                        tfjieldundefined 1 Reply Last reply Reply Quote 0
                        • tfjieldundefined
                          tfjield @fcwilt
                          @fcwilt Oh, you're right, I was thinking backwards. I forgot that he wants to limit extrusion to below the max, not retraction.
                          • ardenpmundefined
                            ardenpm @fcwilt
                            @fcwilt I don't believe PrusaSlicer has custom G-code for retraction.
                            I don't really see doing the above as too big a problem in any case since it's only for these specific priming moves which already have a fairly large amount of Gcode scripting around them, so it's just a few extra lines.
