    How do I calculate powering max accel and velo for steppers?
    • gnydick
      gnydick last edited by
      I have some new XY steppers that are much more powerful, they can sustain higher acceleration rates without skipping steps, however their top speed is lower. I get frequent ~~wire disconnected on drive A/B errors when I try to move fast. These were speeds that the weaker steppers were able to achieve, but had absolutely no torque, so a little bump would move them off track.
      I'd like to get the most out of these steppers, do you have any guidelines for how to figure out the right balance of amps to feed via M906 to get the most out of the motors?
      Item Specification Item Specification
      Phase No. 2 Step Angle 0.9°
      Rated Voltage DC 2.8V/Phase Rated Current DC 2.0A/Phase
      Phase Resistance 1.4x(1+/- 20%)Ω Phase Inductance 3.0x(1+/-20%)mH
      Holding Torque 6.0 Kgf-cm (0.6Nm) Detent Torque 30mN-m REF.
      Rotation Direction A-AB-BA CW Insulation Resistance 100Mohm(DC500V)
      HI-POT AC600V/1mA/1S Insulation Class Class B 130°
      Rotor Inertia 120g-cm2 Weight 0.5Kg REF
      tecno 1 Reply Last reply Reply Quote 0
      • tecno
        tecno @gnydick last edited by
        @gnydick
        Begin here https://www.reprapfirmware.org/emf.html
        gnydick 2 Replies Last reply Reply Quote 1
        • gnydick
          gnydick @tecno last edited by
          @tecno 👏
          • gnydick
            gnydick @tecno last edited by gnydick
            @tecno so, what do I do with the results? Am I to aim for a scenario where the back-pressure-voltage isn't higher than the input voltage? or the back-pressure-voltage is some fraction of the input voltage?
            And, it looks like I have to lower the current waaay dooown to get the speed i'm looking for, but I'm guessing it won't be able to do it with lower power. Is there another calculator that tells you your holding torque?
