Duex5 E stop headers not working
Is it not possible to connect more than 1 runout sensor too the duex 5 e stop headers? If I connect one sensor to any of the headers everything is OK but when I connect 2 the board seems to not boot and wifi does not work.
I am trying to use the E2 AND E3 headers.
Any help would be appreciated.
Do both sensors work individually when connected alone, and on either header?
@phaedrux yes. Either sensor would work on either header as long as there was only 1 connected at a time.
What kind of sensor are they?
Can you show the wiring?
How are they configured?
Firmware version? -
@phaedrux They are just simple sensors.
; Filament Run-Out
M591 D0 P2 C"e0stop" S1 ; E-0 watcher Filament run-out sensor triggers a pause
M591 D1 P2 C"e1stop" S1 ; E-1 watcher Filament run-out sensor triggers a pause
;M591 D2 P2 C"exp.e2stop" S1 ; E-2 watcher Filament run-out sensor triggers a pause
;M591 D3 P2 C"exp.e3stop" S1 ; E-3 watcher Filament run-out sensor triggers a pauseThe duet will not start correctly and does not have any wifi connection when both are connected. If I connect them to the duet board in place of the other 2 everything is ok. So it seems sensors are wired correctly.
I see your endstop voltage select jumper is at 3.3v. I still don't know anything about your sensors, but perhaps 5v would be better?
And your pin names should be
duex.e3stop,
etc -
@phaedrux I didn't change a thing and all of the sudden it all seems to be OK. I have been trying to figure this out for 2 weeks now.
One other question, If any of the sensors do not detect filament it will pause printing even if it is only using 1 extruder. Is there a way to configure it so that only the sensor on the extruder being used will trigger the pause?
I have to disable each sensor or put a piece of filament in each sensor even to print 1 color.
I changed the names for the 3rd and 4th sensors.
; Filament Run-Out
M591 D2 P2 C"duex.e2stop" S1 ; E-2 watcher Filament run-out sensor triggers a pause
M591 D3 P2 C"duex.e3stop" S1 ; E-3 watcher Filament run-out sensor triggers a pause -
@alijambo73 said in Duex5 E stop headers not working:
If you're using tool changes you can disable the sensor in your tpost and only enable it in tpre. That way only the active tool is monitored.
@phaedrux would I use
M591 D0 S1
to enable andM591 D0 S0
to disable and would I need to change S1 to SO disable them in config.g?Shouldn't it be disabled in tfree rather then tpost?
I haven't used these before so I'm tryting to figure it out now. I should have a tfree, tpre and tpost file for each tool correct? I am using a single nozzle with 4 extruders.
Here is what I have for my tfree0.g, tfree1.g, tfree2.g and
M83 ; relative extruder mode G1 E-150 F300 ; retract 150mm G1 E-300 F2500 ; retract 300mm
for tpre0.g,
M591 D0 S1
tpre1.g
M591 D1 S1
tpre2.g
M591 D2 S1
tfree3.g
M591 D3 S1
For tpost0.g, tpost1.g, tpost2.g and tpost3.g
M116 P0 ; wait for tool 0 only to reach operating temperature M83 ; relative extruder mode G1 E450 F2500 ; undo retraction
Does this look OK?
Do I need to include a tool change script in my slicer (simplify 3d) to run the macros?
Sorry for all of the questions. Thanks
