    Too much current goes klunk!
    506
    • brsundefined
      brs
      In the information search along with trial-&-error for setting up my Duet3d converted CreatbotF430 I've learned something(s). Perhaps this will be helpful to the next newbe. That is, too much stepper current seems to make a Klunk sound. I'm not sure why, perhaps someone else can explain it.
      So, the F430 uses two motors which are labeled (in my case) ...
      42HS63-1504A05-D21 & 42HS48-1304JA05-D24
      Technical information was hard to find but this morning I discovered a site that suggested that the current rating is right there in plain sight. Turns out that xxHSxx-1504xxxx and xxHSxx-1304xx means 1.50 amps and 1.30 amps respectively. the xxx4 just means 4 leads. But before finding this information
      I discovered, through trial and error, that running the 42HS63-1504 motor at 1.2 amps was too much.
      Video at 1.2 amps: (turn up your sound)
      42HS63-at-1.2amp.mp4
      Here is the same test but done at 800ma...
      42HS63-at-800ma-.mp4
      • fcwiltundefined
        fcwilt @brs
        @brs said in Too much current goes klunk!:
        It is also related to these settings:
        M566 X900   Y900   Z120 		; max instant speed change (jerk) (mm/min) (defaults 900 900 12) (120 z value from phaedrux)
        M201 X500   Y500   Z240 		; acceleration (mm/s^2) (defaults 500 500 20) (240 z value from phaedrux)
        Try restoring the current and experimenting with these settings so you can see how they can contribute.
        • brsundefined
          brs
          @fcwilt
          I tried tweaking M566 & M201 to no avail. Actually I had increased Y current back to 1200ma and ran my test macro and the klunk didn't happen. Go figure, so perhaps it not the amps after all. However...
          What got me going down this rabbit path was an effort to tune the Y axis. Any help would sure be appreciated. I've activated stealth tune the best that I can figure. When I run my test macro X axis is silent but Y is not. It gets very noticeable when printing a circle tube. Here are my scrips...
          M575 P1 S1 B57600                                  ; enable support for PanelDue
          M550 P"F430"                                       ; set printer name
          M551 P"F430"                                       ; set password
          M552 P192.168.0.200 S1                             ; enable network and set IP address
          M553 P255.255.255.0                                ; set netmask
          M554 P192.168.0.1                                  ; set gateway
          M569 P0.1 S0                                       ; physical drive (X axis) 0.1 goes backwards
          M569 P0.2 S0                                       ; physical drive (Y axis) 0.2 goes backwards
          M569 P0.3 S1                                       ; physical drive 0.3 goes forwards
          M569 P0.4 S1                                       ; physical drive 0.4 goes forwards
          M584 X0.1 Y0.2 Z0.3 E0.4                           ; set drive mapping
          M92 X78.82 Y131.23 Z640.00 E415.00                 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous (JERK) speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z600.00 E1200.00            ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
          M906 X800 Y1200 Z1200 E650 I30                     ; set motor currents (mA) and motor idle factor in per cent
          M208 X420 Y300 Z290 S0                             ; set axis maxima
          M574 X1 S1 P"io1.in"                               ; configure microswitch endstop for low end on X via pin io1.in
          M574 Y1 S1 P"io2.in"                               ; configure microswitch endstop for low end on Y via pin io2.in
          M574 Z2 S1 P"io5.in"                               ; configure microswitch endstop for High end on Z via pin io5.in
          ;M574 Z2 S2                                         ; configure Z-probe endstop for high end on Z
          M950 S0 C"io7.out"                                 ; create servo pin 0 for BLTouch
          M558 P9 C"io7.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X-4 Y75.5 Z3.1                            ; set Z probe trigger value, offset and trigger height
          M557 X5:400 Y76:286 S30                            ; define mesh grid
          M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
          M950 H0 C"out3" T0                                 ; create bed heater output on out3 and map it to sensor 0
          M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
          M143 H0 S160                                       ; set temperature limit for heater 0 to 160C
          M308 S1 P"temp1" Y"pt1000"                         ; configure sensor 1 as PT1000 on pin temp1
          M950 H1 C"out1" T1                                 ; create nozzle heater output on out1 and map it to sensor 1
          M143 H1 S420                                       ; set temperature limit for heater 1 to 420C
          M308 S2 P"temp2" Y"thermistor" T100000 B4138       ; configure sensor 2 as thermistor on pin temp2
          M950 H2 C"out2" T2                                 ; create chamber heater output on out2 and map it to sensor 2
          M307 H2 B1 S1.00                                   ; enable bang-bang mode for the chamber heater and set PWM limit
          M141 H2                                            ; map chamber to heater 2
          M143 H2 S70                                        ; set temperature limit for heater 2 to 70C
          M950 F0 C"out4" Q3000                              ; create fan 0 on pin out4 and set its frequency
          M106 P0 C"Part Cooler" S0 H-1                      ; set fan 0 name and value. Thermostatic control is turned off
          M950 F1 C"out5" Q4000                              ; create fan 1 on pin out5 and set its frequency
          M106 P1 C"HotEnd" S0 H1 S0.5 T100                  ; set fan 1 name and value. Thermostatic control is turned on
          M950 F2 C"out8" Q500                               ; create fan 2 on pin out8 and set its frequency
          M106 P2 C"onXstepper" S0.15 H-1                    ; set fan 2 name and value. Thermostatic control is turned off
          M950 F3 C"out9" Q500                               ; create fan 3 on pin out9 and set its frequency
          M106 P3 C"Duet-board" S0.1 H-1                     ; set fan 3 name and value. Thermostatic control is turned off
          M501                                                ; load saved parameters from non-volatile memory
          M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"  ; set voltage thresholds and actions to run on power loss
          M150 x0 R100 U100 B100 P100 S107			 ; set DotStar LEDs (dim white)
          T0                                                  ; select first tool
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Fri Jun 10 2022 15:08:30 GMT-0700 (Pacific Daylight Time)
          G1 H2 Z5 F6000          ; lift Z relative to current position
          G1 H1 X-425 Y-305 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000       ; go back a few mm
          G1 H1 X-425 Y-305 F360  ; move slowly to X and Y axis endstops once more (second pass)
          ;stealthchop tuning AT1
          M18 X Y                            ; disable x and y steppers
          M569 P0.1 D3 V5 H5                 ; enable stealthchop and set tpwmthrs and thigh for X
          M569 P0.2 D3 V5 H5                 ; enable stealthchop and set tpwmthrs and thigh for Y
          M915 P0.1 T5                       ; set tcoolthrs for X [needed if stallguard is not used???]
          M915 P0.2 T5                       ; set tcoolthrs for Y [needed if stallguard is not used???]
          M17 X Y                            ; enable x and y steppers [will this enable full run current or idle current???]
          G4 P150                            ; pause for 150ms to satisfy AT1 condition
          G92 X0 Y0                          ; set home positions again after position loss due to M18
          ;stealthchop tuning AT2 (and goto probe bed-center)
          G1 X200 Y75 F6000       ; tuning move at "typical speed" that is nearly a straight line...
                                  ; ...in order to move both steppers (CoreXY) significantly i.e. >400 full steps @ 60-300RPM
          ;homing z
          G1 X209 Y 67.5
          G30                     ; home Z by probing the bed
          G1 Z50 F1000            ; lift Z relative to current position
          • brsundefined
            brs
            More learning
            More questions
            In regard to the videos in the first post.
            -with StealthC off and the Y current reduced to 1100ma, a Y only move does-not create that 'bark' sound when changing directions. Though it 'barks' above 1100ma.
            -with StealthC on (current still at 1100ma) a Y only move does create that 'bark' sound.
            Q: why?
            • with StealthC on, a linear move in either X or Y is very quite (except for the Y 'bark').
            • still with StealthC on, again, a diagonal move from X to Y is very noisy.
            Q: why?
            ....Five minutes later
            I just disabled StealthChop on the Y axis but left it on for the X axis. This works much better! Seems there is an issue with StealthChop and the Y motor.
            Q: Any Ideas Why?
            moth4017undefined 1 Reply Last reply Reply Quote 0
            • moth4017undefined
              moth4017 @brs
              @brs
              your find there is more friction on the X axis, just turn off the motors and move the X and Y axis by hand.
              do you have different types of stepper motor on Y and X?
              brsundefined 1 Reply Last reply Reply Quote 0
              • brsundefined
                brs @moth4017
                @moth4017
                Yes X an Y are very different. Much less friction on X than Y.
                X drives just a belt (so 1:1) and the motor is only about an inch tall. Only moves the head.
                Y drives the gantry through a step-up pulley (~1.7:1) which drives a shaft to two belts one on each side to the gantry. The motor is about 2.5" (60mm).
                • moth4017undefined
                  moth4017 @brs
                  @brs the klunk on the video sound like something
                  is loose
                  • brsundefined
                    brs @moth4017
                    @moth4017 said in Too much current goes klunk!:
                    is loose
                    Ha, no not at all - nothing is loose. But yes, kinda sounds like it. It's demonstrably related to Current and StealthChop. No doubt there is much more to it, but it's not physical, at least not the cause. It amazes me how these steppers bing 90% electric/electronic can make such a variety of sounds. Do the sounds come from that 10% mechanical? Makes no sense to me.
                    • fcwiltundefined
                      fcwilt @brs
                      @brs
                      It's usually the sudden acceleration/deceleration that leads to that sound.
                      I had it on one printer. Changing the acceleration and "jerk" parameters got rid of it with little impact on performance.
                      • brsundefined
                        brs @fcwilt
                        @fcwilt said in Too much current goes klunk!:
                        @brs
                        Frederick, per your previous post (and my response) I already spent considerable time tweaking M566 & M201. Nothing seemed to make any difference. Thanks though.
                        • fcwiltundefined
                          fcwilt @brs
                          It's hard to remember what I have responded to and what I have yet to respond to.
                          Sorry about that.
                          It should have been able to silence it completely. I do not understand why it couldn't.
