    M906 Motor current idle factor per axis
    Firmware wishlist
    • oozeBotundefined
      oozeBot
      @dc42 - would it be possible to modify the firmware to set the idle factor per axis? As you saw with our printers, the z-axis is belt driven and requires a high idle percentage to remain stationary where the other axes do not. Thanks
      edit great to meet you, btw!
      tecnoundefined 1 Reply Last reply Reply Quote 0
      • tecnoundefined
        tecno @oozeBot
        @oozebot
        M906 line for each axis with I value is what I do
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • oozeBotundefined
          oozeBot @tecno
          @tecno I just re-tested to make sure it wasn't that simple.. that appears to set the idle factor to the value in the last M906. Thanks
          tecnoundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • tecnoundefined
            tecno @oozeBot
            @oozebot
            I have to check and see the behaviour on my printers. Interesting....
            • tecnoundefined
              tecno @tecno
              @oozeBot
              You are so right, missed that one. M906 line can only have one I value. I hope we can get a solution for this.
                jay_s_uk @oozeBot
                @oozebot I believe it's in the list to look at. It's currently only a single value for all
                dc42undefined 1 Reply Last reply Reply Quote 2
                  dc42 administrators @jay_s_uk
                  @jay_s_uk correct, I plan to support per-axis idle current percentage in RRF 3.5.
