Panel misbehaviour
PanelDue 7i
firmware: 3.4.1-pre1
if i touch current temperature then its press emergency stop. or same thing happens in blank space also. -
@dp_23 can you share some additional details like the duet board you are using and how you wired up the panel? Maybe a photo of the housing if you use any?
@oliof i am using Duet 3 MB6HC board
and I have tried on the open board -
@oliof and i have 4 panel due. but only one panel is not working properly. All panel have same firmware or same connection.
Have you redone a touch calibration?
Do you have a case on the Panel? Is it pressing against the screen?
