    M300 making a sound in Paneldue & DWC?
    Firmware wishlist
    • Yaoundefined
      Yao
      Is it possible t have DWC play a sound (M300) while paneldue is attached?
      I need a louder sound than Paneldue can produce.
      Yaoundefined engikeneerundefined 2 Replies Last reply Reply Quote 2
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
      • Yaoundefined
        Yao @Yao
        @yao aha, so not possible yet?
        • OwenDundefined
          OwenD
          @yao
          I don't see how it would be possible for DWC to provide a beep from an M300 call.
          Browsers don't typically have hardware access to the pc without some sort of add-in.
          However there's nothing stopping you using an output to control a really driven piezo buzzer, siren, flashing lights or whatever.
          Yaoundefined 1 Reply Last reply Reply Quote 0
          • Yaoundefined
            Yao @OwenD
            @owend I read somewhere (i could interpret wrong) that if a paneldue is attached DWC does not make a sound. but without Paneldue installed it does with the M300 ?
            "Play beep sound, use to notify events like the end of printing. If an LCD device is attached to RepRapFirmware, a sound is played via the add-on touch screen control panel. Else the web interface will play a beep sound."
            found the 'somewhere':
            https://docs.duet3d.com/User_manual/Reference/Gcodes#m300-play-beep-sound
            OwenDundefined 1 Reply Last reply Reply Quote 0
            • OwenDundefined
              OwenD @Yao
              @yao
              I stand corrected.
              Seems there's a javascript audio API for doing beep sounds.
              • Yaoundefined
                Yao @OwenD
                @owend well, unfortunately only through paneldue when installed, would be nice if it was an option, or both to make it even more audible.
                • engikeneerundefined
                  engikeneer @Yao
                  @yao Bump!
                  Definitely think this is a good idea! I have my printers in the garage, so have a Panel Due for inteacting with them in there, but tend to 'monitor' them via DWC from the house. Currently I have resorted to using a 'tuned' move which hits the midband resonance of the steppers to make a short tune which can usually be heard from afar, but this does feel a bit janky... 😛
                  This might also appease some of the comments that the small PanelDue buzzer isn't loud enough for their needs
                  i3 clone with a bunch of mods
