Pressure Advance Calibration Routine
The routine here: https://duet3d.dozuki.com/Wiki/Pressure_advance#:~:text=The most simple method of,the middle of a face
states using a 100mm cube. But the routine is 40mm in total height. What happen after the 40mm, does PA stay at 0.35 or go back to off or none?.
I am using Simplfy3D for a slicer. -
The value will stay whatever the last value sent was.
You can modify the routine to add more changes or whatever you'd like.
@phaedrux thank you for the reply.
