Input shaping plugin, need src code pointer
Just a note that multiple peaks usually means there are some loose things that get excited. The printheead ringing frequency of current printer designs usually is somewhere between 5Hz (Anet A 8 levels of stability) and 80-90Hz (V Core / Voron). Higher ringing frequency more often than not points towards overtensioned belts.
thanks for the pointers, @oliof
Turn you, @resam !
