    Independent Z Motors- Endstop Error
    Using Duet Controllers
    367
    • JRCLundefined
      JRCL
      Hello all!
      I'm working on a machine with independent Z motors which are on either end of the X-axis. I hoped to use high-end, end-stops to level the X-axis at the top of the Z before using a BL Touch to probe the bed and establish my Z datum in my "homez.g".
      However I'm getting 'G28 Z // Error: Failed to enable endstops' when I home Z. Here is my config and homez.g, which is on a Duet 2 Wifi and Duex 5. Previously I had just the Z probe, but when I went to add the two endstops I started getting the error.
      ; Configuration file for Duet WiFi (firmware version 3.3)
      M575 P1 S1 B57600                               ; enable support for PanelDue
      G90                                             ; send absolute coordinates...
      M83                                             ; ...but relative extruder moves
      M550 P"RL1 Proto V2"                              ; set printer name
      M569 P0 S1                                      ; physical drive 0 goes forwards (eventually X)
      M569 P1 S1                                      ; physical drive 1 goes forwards (eventually Y)
      M569 P2 S1                                      ; physical drive 2 goes forwards (eventually Z)
      M569 P3 S1                                      ; physical drive 3 goes forwards (eventually E)
      M569 P4 S0										; physical drive 5 goes backwards (eventually U1)
      M569 P5 S0										; physical drive 6 goes backwards (eventually U2)
      M950 P0 C"duex.pb6" 								; assign servo control to port 0 and link to PB6 GPIO on duex
      ; Motor Speeds and Accelerations
      M584 X0 Y1 Z2 E3 U4:5                               ; set drive mapping
      M350 X16 Y16 Z16 E16 U16 I1                     		 	; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E415.38918 U80        					; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00 U900    				; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00 V6000 				; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00 U500.00 				; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 U800 V 800 I60                	; set motor currents (mA) and motor idle factor in per cent
      M208 X-40 Y-10 Z0 U0 S1                                ; set axis minima
      M208 X313 Y174 Z300 U500 S0                          	; set axis maxima
      M574 X2 S1 P"xstop"                            	; configure switch-type (e.g. microswitch) endstop for high end on X
      M574 Y2 S3                                      ; configure sensorless endstop for high end on Y
      M574 Z2 S1 P"zstop+e2stop" 						; configure active-high endstops on Z via pins zstop and e1stop
      M574 U2 S1 P"e1stop" 							; configure switch-type (e.g. microswitch) endstop for high end on U via pin e1stop
      M915 X R0 F0 S1 								; configure stall detection for x
      M915 Y R0 F0 S3 								; configure stall detection for Y
      M950 S0 C"duex.pwm1" 							; Duet 2 WiFi/Ethernet + DueX2/5
      M558 P9 C"^zprobe.in" H5 F120 T6000 			; Duet 2 WiFi/Ethernet, DueX2/5
      G31 P500 X-7 Y0 Z6.017        				; set Z probe trigger value, offset and trigger height
      ;homez.g
      G91                		; relative mode
      G1 H1 Z320 F5000 		; move quickly to Z axis endstop and stop there
      G90               	 	; back to absolute mode
      G1 X30 Y100 F2000 		; put head over the centre of the bed, or wherever you want to probe
      G30                		; lower head, stop when probe triggered and set Z to trigger height
      G1 X0 Y0 Z15			; send to over origin
      • JRCLundefined JRCL marked this topic as a question
        Can you send M122 and M98 P"config.g" and post the results?
        Can you also post your homeall?
        Does G30 by itself work to use the probe?
        JRCLundefined 1 Reply Last reply Reply Quote 0
        • JRCLundefined
          JRCL @Phaedrux
          @Phaedrux
          Yes the probe works by itself. Posted results below:
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.3 (2021-06-15 21:44:54) running on Duet WiFi 1.02 or later + DueX5
          Board ID: 08DGM-917NK-F2MS0-7JKDL-3SN6J-TDS0G
          Used output buffers: 3 of 24 (12 max)
          Static ram: 23876
          Dynamic ram: 75920 of which 0 recycled
          Never used RAM 14620, free system stack 184 words
          Tasks: NETWORK(ready,12.9%,237) HEAT(delaying,0.0%,330) Move(notifyWait,0.1%,340) DUEX(notifyWait,0.0%,24) MAIN(running,86.1%,441) IDLE(ready,0.9%,29), total 100.0%
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:01:25 ago, cause: power up
          Last software reset at 2022-07-10 16:28, reason: User, GCodes spinning, available RAM 11412, slot 1
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 0
          MCU temperature: min 23.1, current 28.5, max 29.0
          Supply voltage: min 24.1, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: position 0, standstill, SG min/max not available
          Driver 1: position 0, standstill, SG min/max not available
          Driver 2: position 0, standstill, SG min/max not available
          Driver 5: position 0, standstill, SG min/max not available
          Driver 6: position 0, standstill, SG min/max not available
          Driver 7: position 0, standstill, SG min/max not available
          Driver 8: position 0, standstill, SG min/max not available
          Driver 9: position 0, standstill, SG min/max not available
          Driver 10: position 0
          Driver 11: position 0
          Date/time: 2022-07-10 17:56:00
          Cache data hit count 3106634543
          Slowest loop: 5.08ms; fastest: 0.17ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 4.2ms, write time 0.0ms, max retries 0
          === MainDDARing ===
          === AuxDDARing ===
          Bed heaters = -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === DueX ===
          Read count 1, 0.70 reads/min
          === Network ===
          Slowest loop: 15.60ms; fastest: 0.00ms
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.26
            WiFi MAC address 24:a1:60:2e:a8:8a
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 21600
            WiFi IP address 192.168.1.98
            WiFi signal strength -42dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00002002
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: Unknown pin name 'fan3'
          Error: Fan number 3 not found
          ;homeall
          M98 P"homeu.g"
          M98 P"homex.g"
          M98 P"homey.g"
          M98 P"homez.g"
          Looks like I have a fan to fix too 😁
            Phaedrux Moderator @JRCL
            @jrcl said in Independent Z Motors- Endstop Error:
        ;homeall        M98 P"homeu.g"        M98 P"homex.g"        M98 P"homey.g"        M98 P"homez.g"
            Can you post those as well?
            • JRCLundefined
              JRCL @Phaedrux
              @phaedrux
              ;homeu.g
              G91; relative positioning
              G1 H1 U700 F5000 ; move quickly to U axis endstop and stop there (first pass)
              G90 ; absolute positioning
              ;homex
              G91					;relative positioning
              G1 H2 Z10 F200      ; raise head 10mm to ensure it is above the Z probe trigger height
              G1 H1 X450 F10000 	; move quickly to X axis endstop and stop there (first pass)
              G1 X0 F10000		; move to zero on x axis
              ;homey.g
              G91					; relative positioning
              G1 H2 Z10 F200      ; raise head 4mm to ensure it is above the Z probe trigger height
              G1 H1 Y320 F10000 ; move quickly to X axis endstop and stop there (first pass)
              G1 H2 Y-5 F12000 ; go back a few mm
              G1 H1 Y320 F7000 ; move slowly to X axis endstop once more (second pass)
              G1 H1 Y0 F10000 ; move to 0 on y axis
              ;homez.g
              G91                		; relative mode
              G1 H1 Z320 F5000 		; move quickly to Z axis endstop and stop there (first pass)
                What is the U axis? You have two endstops defined for Z, but only a single driver. You have two drivers assigned to U, but only a single endstop.
                You also seem to be referencing a V axis...
                JRCLundefined 1 Reply Last reply Reply Quote 1
                • JRCLundefined
                  JRCL @Phaedrux
                  @phaedrux U axis is an external carriage for thermoforming. What is a driver in this case? One end stop on the U was intentional as it doesn't need to be very level.
                  Whoops the V's should be gone, the firmware was copied from an old one to start which had a V axis. Looks like I missed a few!
                    You can only use independent Z motor leveling with 2 endstops if you are using 2 independent drives for the Z axis.
                    • JRCLundefined
                      JRCL @Phaedrux
                      @phaedrux Ohhh, I see. So I can't use both the Z drive connections, the other has to use a different driver.
                        The 2 Z motor connectors on the board are wired in series to the same driver. To get independant control, you'd need to use a second driver for the second motor.
                        See here for more details.
                        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_auto_levelling
                        You're on the right start. Once you fix up the driver mappings and clean up the U/V stuff it should work.
                        JRCLundefined 2 Replies Last reply Reply Quote 1
                        • JRCLundefined
                          JRCL @Phaedrux
                          @phaedrux Awesome! Wouldn't have figured that one out for a bit 🙂 should be an easy fix then, thanks for the help.
                          • JRCLundefined JRCL has marked this topic as solved
                          • JRCLundefined JRCL has marked this topic as unsolved
                          • JRCLundefined
                            JRCL @Phaedrux
                            @phaedrux
                            Here is my new config.g with updated driver setup and elimination of V axis. Made sure my end stop wiring corresponded to the drivers in the same order as the pin call out "zstop+e2stop" as well. I'm still getting a G28 Z Failed to Enable End Stops, error message.
                            M569 P2 S1                                      ; physical drive 2 goes forwards (eventually Z1)
                            M569 P4 S0										; physical drive 4 goes backwards (eventually U1)
                            M569 P5 S0										; physical drive 5 goes backwards (eventually U2)
                            M569 P6 S1										; physical drive 6 goes forwards (eventually Z2)
                            M584 X0 Y1 Z2:6 E3 U4:5                               ; set drive mapping
                            M203 X6000.00 Y6000.00 Z180.00 E1200.00 U6000 				; set maximum speeds (mm/min)
                            M906 X800 Y800 Z800 E800 U800 I40                	; set motor currents (mA) and motor idle factor in per cent
                            M208 X160 Y170 Z300 U500 S0                          	; set axis maxima
                            Phaedruxundefined dc42undefined 2 Replies Last reply Reply Quote 0
                              You're only getting that error when you send G28 Z?
                              Does homeall work?
                              Can you send M119 and share the results?
                              Can you send M574 and share the results?
                                dc42 administrators @JRCL
                                I suspect that line isn't working as intended. As you have a DueX in the system, you should use this:
                                M574 Z2 S1 P"zstop+duex.e2stop"
                                JRCLundefined 1 Reply Last reply Reply Quote 2
                                • JRCLundefined
                                  JRCL @dc42
                                  @dc42 Aha! That fixed the problem, Z is homing as expected now. Thank you!
