having problems connecting with pc
Hello..
Try to search but found nothing..
For some time i didn't use the printer (2 months +/-)
This night try to connect but no luck..
Try to connect with the pc and nothing..
But by phone i can... i uploaded to the last version: 3.4.1rc1.
Ok no error..
By phone i acess the printer, but using the pc nop...
The IP is the same...Can only acess by wireless..
help me if.. possible..
please.. -
It sounds like you are able to connect to the printer when using your phone over wireless, but not from your PC that is wired?
Has something changed with your router since the last time you used the printer? Some routers will segregate wireless clients from wired clients. That may be what's happening here.
What IP does the Duet have?
What IP does your phone have?
What IP does your PC have?Are they all in the same subnet?
Are you able to ping the Duet IP address from your PC?
@phaedrux
Thanks for help me.
After changing door of the router and reboot... start to work again.
I don't know what happen.. but works ok now.Thanks
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
