    Additional PID Tuning for 1000W Heater
    • JRCLundefined
      JRCL
      I have a 1000W finned heating element that is controlled via a relay connected to my Duet 2 wifi. After several attempts to autotune the element, I still get a heater too slow fault each time I use it due to its very slow initial warm-up. I'm wondering if anyone has recommendations on workarounds or which variables to adjust first. Here is the M307 line for the heating element.
      M307 H2 B0 R0.639 C402.9 D46.76 S1.00 V24.3
      • JRCLundefined JRCL marked this topic as a question
        You could try manually increasing the deadtime by editing the D value. Try 100 seconds. Though that may lead to a bit of overshoot as well.
        JRCLundefined 1 Reply Last reply Reply Quote 0
        • JRCLundefined
          JRCL @Phaedrux
          @phaedrux Unfortunately this didn't get me through the fault. Some overshoot isn't a big deal for this application.
            Where is the thermistor for this heater located in relation to the heater itself?
            JRCLundefined 1 Reply Last reply Reply Quote 1
            • JRCLundefined
              JRCL @Phaedrux
              @phaedrux The thermistor had in fact gotten further away from my element than intended. Thanks for the reminder, things are working as expected again!
              • JRCLundefined JRCL has marked this topic as solved
