    BL Touch deploying when printer plugged in, but not with GCode
    Using Duet Controllers
    • Tryptamineundefined
      Tryptamine
      I am using a legitimate BL Touch on a Duet Wifi, wired according to https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_connecting
      Wiring the BLTouch
      Duet 2 Wifi without Expansion Board
      When I run M401 nothing happens.
      My deployprobe.g says M280 P0 S10
      Running M280 P0 S10 directly, also nothing happens.
      When I was using my printer the last time (like one year ago, back in FW 2.x) the probe was working. Now I got it to my new place, updated Firmware to 3.3 and the probe does not deploy.
      I first thought some part of my wiring broke.
      But when I plug in the printer's power, the probe deploys and retracts 3 times, so this is no electrical issue.
      config.g
      Help is greatly appreciated.
        droftarts administrators @Tryptamine
        @tryptamine If your BLTouch is wired as in the picture, the servo pin should be exp.heater3, not exp.heater4 as in your config.g. In config.g change the M950 line to:
        M950 S0 C"exp.heater3"                             ; create servo pin 0 for BLTouch
        Tryptamineundefined 1 Reply Last reply Reply Quote 1
          Tryptamine @droftarts
          @droftarts you are a hero.
