    wires to the stepper motors fell off,
    Other control boards
    • gojDKundefined
      gojDK
      hi, I ran into a problem, one of the belts broke, so I had to remove the bottom, that's where my problem arose, all the wires to the stepper motors fell off, does anyone know which wires belong to which motor E2, E3 , E4 , E5?
      I forgot to mention that it is a Vivedino Troodon
      alankilianundefined Norderundefined 2 Replies Last reply Reply Quote 0
      • alankilianundefined
        alankilian @gojDK
        @gojdk
        If it follows good sense engineering, the first motor will be E2, the second one will be E3 the third one will be E4 and the last one will be E5.
        • Norderundefined
          Norder @gojDK
          @gojdk said in wires to the stepper motors fell off,:
          Duet2 Board ?
          https://docs.duet3d.com/en/How_to_guides/Wiring_your_Duet_2
          DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
          Thingiverse
          • gojDKundefined
            gojDK
            This post is deleted!
