Additional axis not working on Paneldue
I have two additional Axis on my printer (on the DueX5), Configured as C for a Toolchanging coupler and A for a Height adjustable wiper.
In the web interface these appear as expected and the movement controls work. On the paneldue however They appear as U and V rather than C and A.
Current position shows correctly but the movement buttons don't work on the Paneldue. I don't get an error, they just have no effect for either of those two axis.
DWC = Duet Web Control 3.4.0
FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet WiFi 1.02 or later + DueX5v0.11 FIRMWARE_DATE: 2022-03-15 18:58:33
Paneldue=1.24In all other respects these axis work fine, but particularly for the wiper it would be handy if I could run manual movements from the display.
Is this a bug or something wrong in my config?
Many Thanks.
@digimatic said in Additional axis not working on Paneldue:
Paneldue=1.24
I think this should be fixed by updating your PanelDue firmware. You are on 3.4 on the Duet, use 3.4 for the PanelDue. See https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_PanelDue
Use files from https://github.com/Duet3D/PanelDueFirmware/releases
The latest pre-release (PanelDue-3.4.1-pre3) has a couple of bugs fixed compared to the latest release (PanelDue-3.4.0), so I recommend to use that.Ian
Thank you, hadn't even noticed that my paneldue version should match, updated and problem is resolved.
