    Valkyrie High Temp DIY Corexy
    My Duet controlled machine
    1
    • pro3dundefined
      pro3d
      After 15 months of development she is finally done. Release will be august 1 2022. Duet controlled by any 6+ axis combo.
      Project-Valkyrie
      A DIY High-Temp 3D Printer project designed by professionals to be a premium DIY FFF/FDM 3d printer
      • https://vkingprinter.com/project-valkyrie/
      • https://discord.gg/C77tsY5
      Valkyrie Main Features
      Advanced Kinematics with independent triple Z axis
      • Fully automated bed leveling
      • Inverted CoreXY for minimal friction
      • XUV Triple Z True Bed Leveling with Maxwell Coupling Criteria
      • Stall-detection homing on all 2+3 – XY+ZUV axis
      • Light tool-head riding on carbon X with MGN9h
      • ABZUV stepper motors all located in the cold zone
      Temperature Controlled Heated Chamber <80C
      • Engineered insulation options for high level of safety and minimal thermal loss
      • High end ACM Outer Paneling
      • Double glazed window for inside viewing and good insulation
      Integrated Temperature Controlled Heated Dry-box
      • Filament weight control by load-cell
      • Dry-box temp control <70C
      • Dry-box humidity sensor
      Advanced Firmware add-ons
      • Chamber temp controls and display
      • Dry-box temp control and display
      • Dry-box humidity display
      • Filament weight display
      • Extruder motor temp sensor and display
      Water-cooled hotend
      • Option to water-cool extruder stepper motor
      Other features
      • High temp belts 9mm gates 2GT on all axis
      • Easy access belt tension system on all axis
      • Having high quality motors, idlers and other key components
      • Solid frame with low center of gravity
      • Seperate AC and DC systems
      IMG_20220722_095651.jpg IMG_20220722_095721__01.jpg IMG_20220722_095738.jpg IMG_20220723_141509.jpg
      Valkyrie DIY High Temp 3D Printer
      R&D - Engineering Designer - Viking 3D Printers
      pro3dundefined 1 Reply Last reply Reply Quote 2
      • pro3dundefined
        pro3d @pro3d
        This bad girl is now officially released
        https://github.com/RoyBerntsenDesign/Project-Valkyrie/releases/tag/V1.0
