Duet 3 Flash custom firmware via swd
I was trying to create some custom firmware for the Duet 3 6HC board. The reason for this is, that the hardware supports all the necessary functionality but I don't need the WebServer etc. for my particular application. When I bought the Duet 3 I saw in the hardware docs, that there is a SWD connector. So I thought that I would be able to just open an openocd connection, compile my firmware, flash it on the chip via SWD and use a arm-none-eabi-gdb for debugging. Boy was I wrong
I am using the following:
- Duet 3 6HC v1.01
- STLink V2 and a STLink V2.1 turned into a Jlink, I have tried everything with both
- Openocd v0.11.0
- arm-none-eabi-gcc 10.2.1
Using the following command
openocd -f interface/jlink.cfg -c "transport select swd" -f target/atsamv.cfg I am able to establish an openocd connection to the ATSAME70Q20B processor. I have build some dummy firmware using a Makefile Project created using ATMEL START for the corresponding processor. I was able to compile an elf file, connect my gdb to the openocd socket and flash that firmware. However as soon as I try to create a breakpoint in the main function to step through the programm, it gets stuck in the following backtrace loop and never reaches main:
#0 0x00800dbe in ?? () #1 0x20400100 in _sheap () I tried erasing over the jumper and reflashing the firmware. Didn't help. I then tried to restore the Reprapfirmware v3.3. I successfully build it using the tutorial, and tried to flash it over swd and got the following error:
(gdb) load Loading section .text, size 0x8947c lma 0x400000 Loading section .ARM.extab, size 0x14f4 lma 0x48947c Loading section .ARM.exidx, size 0x18f0 lma 0x48a970 Loading section .relocate, size 0x638 lma 0x48c260 Error finishing flash operation openocd output:
Info : erasing lock regions 0-35... Info : erasing lock region 0 Info : erasing lock region 1 Info : erasing lock region 2 Info : erasing lock region 3 Info : erasing lock region 4 Info : erasing lock region 5 Info : erasing lock region 6 Info : erasing lock region 7 Info : erasing lock region 8 Info : erasing lock region 9 Info : erasing lock region 10 Info : erasing lock region 11 Info : erasing lock region 12 Info : erasing lock region 13 Info : erasing lock region 14 Info : erasing lock region 15 Info : erasing lock region 16 Info : erasing lock region 17 Info : erasing lock region 18 Info : erasing lock region 19 Info : erasing lock region 20 Info : erasing lock region 21 Info : erasing lock region 22 Info : erasing lock region 23 Info : erasing lock region 24 Info : erasing lock region 25 Info : erasing lock region 26 Info : erasing lock region 27 Info : erasing lock region 28 Info : erasing lock region 29 Info : erasing lock region 30 Info : erasing lock region 31 Info : erasing lock region 32 Info : erasing lock region 33 Info : erasing lock region 34 Info : erasing lock region 35 Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (2156 ms). Workaround: increase "set remotetimeout" in GDB Info : SWD DPIDR 0x0bd11477 Error: Failed to write memory and, additionally, failed to find out where Error: failed to buffer page at 0x00400000 Error: error writing to flash at address 0x00400000 at offset 0x00000000 Info : SWD DPIDR 0x0bd11477 Polling target samv.cpu failed, trying to reexamine Info : SWD DPIDR 0x0bd11477 Info : SWD DPIDR 0x0bd11477 Error: Could not find MEM-AP to control the core Examination failed, GDB will be halted. Polling again in 100ms Info : SWD DPIDR 0x0bd11477 Info : SWD DPIDR 0x0bd11477 Error: Could not find MEM-AP to control the core Info : SWD DPIDR 0x0bd11477 Info : SWD DPIDR 0x0bd11477 Info : SWD DPIDR 0x0bd11477 Info : SWD DPIDR 0x0bd11477 Info : AP write error, reset will not halt Error: DP initialisation failed Error executing event gdb-flash-write-end on target samv.cpu: What am I missing? Can someone provide me with a tutorial on how to flash the Duet 3 Mainboard via SWD?
Any help is greatly appreciated. Best regards
@andgl
I really don't know much how to help, but do these files in THIS GUTHUB LOCATION help?
They talk about openocd and SWD.
or maybe the linker script in THIS LOCATION?
@alankilian Thank you for your response. Sadly the openocd script in github is for another in-cirtcuit debugger device, namely a cmsis-dap. I am using a stlink however and my openocd command basically contains the whole contents of the script, but as cmd line parameters. As far as I can tell there should not be an issue using the stlink over the cmsis-dap (at least in theory)
@andgl I have no problem flashing firmware or debugging over SWD using a Atmel ICE. I originally tried using a Black Magic SWD probe instead, but it turned out that the firmware didn't support the Atmel/Microchip ATSAM MCUs.
@dc42 If it's not too much to ask, could you please try flashing a custom Atmel Start project with your setup? Just to make sure, that the issue is not due to some wrong linkerfile settings. Atmel Start can generate you a makefile project with a dummy main function for the ATSAME70Q20B without having to register or anything.
@andgl if you are using Atmel Start then be aware that it is very buggy, based on my experience with using Atmel Start with the SAME5x processors. Microchip doesn't support it and hasn't fixed showstopper bugs that I reported more than three years ago. I don't have time to set up a SAME70 Atmel Start project and work through the likely bugs.
Are you sure that your stlink hardware and openocd firmware will work with the SAME70? Have you tried loading and debugging the same Atmel Start project using a Atmel ICE?
