    Heater fault when trying to enable tool
    • ov_darknessundefined
      ov_darkness
      I'm building "Turbo Ender 3" with Duet 2 Wifi, LGX and Mosquito hotend.
      This is my first time with RRF3.4.1
      My issue is that I probably misconfigured heaters and have no idea where to go from here.
      When trying to heat either bed or head, it gives me fault.
      I've tested PT100 (as you can see by two M308 values) and it works ok.
      I've also tested another thermocouple amplifier.
      I don't have a second TC though.
      I've also encountered an issue when connecting the Slice heater to Duet.
      When the heater is disconnected, thermocouple readings are sane.
      When I connect the heater, there's an error message about a possible short.
      This is how my config.g looks like:
      M575 P1 S1 B57600                              ; enable support for PanelDue
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Ender 3"                                ; set printer name
      M918 P1 E4 F2000000                            ; configure direct-connect display
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S0                                     ; disable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S0                                     ; physical drive 1 goes backwards
      M569 P2 S1                                     ; physical drive 2 goes forwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E121.00              ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z180.00 E6000.00        ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z100.00 E5000.00        ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X235 Y235 Z260 S0                         ; set axis maxima
      M574 X1 S1 P"^xstop"                           ; configure sensorless endstop for low end on X
      M574 Y1 S1 P"^ystop"                           ; configure sensorless endstop for low end on Y
      M574 Z1 S1 P"^zstop"                           ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin ^zstop
      M558 P0 H5 F120 T6000                          ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                       ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S110                                   ; set temperature limit for heater 0 to 110C
      ;M308 S1 P"spi.cs1" Y"thermocouple-max31856"   ; create sensor number 1 as a thermocouple, defaulting to type K in the first position on the Duet 2 daughter board connector
      M308 S1 P"spi.cs1" Y"rtd-max31865"			   ; create sensor number 1 as a PT100 sensor in the first position on the Duet 2 daughterboard connector
      M950 H1 C"e0heat" T1						   ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                   ; set temperature limit for heater 1 to 300C
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H T45                               ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H-1                                 ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 D0 H1 F0:1                             ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M501                                           ; load saved parameters from non-volatile memory
      T0                                             ; select first tool
      Pro level AM audit, support and sales.
      Management of 3D scanning and printing services.
      Focused on Central and Eastern Europe.
        Phaedrux Moderator @ov_darkness
        @ov_darkness said in Heater fault when trying to enable tool:
        Check your wiring. There is possibly a short.
        What is the fault message? Have you PID tuned the heaters and saved the results?
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning
        Are you using thermocouples, or PT100, or thermistors?
        If thermocouple or PT100 do you also have the corresponding Duet daughterboard?
        ov_darknessundefined 1 Reply Last reply Reply Quote 0
          ov_darkness @Phaedrux
          @phaedrux said in Heater fault when trying to enable tool:
          I've triple checked (with a hi-quality multimeter). There's no short. I've found some info that it can be a grounding issue.
          My fault message with TC is
          Heater 1 fault: failed to read sensor: sensor short to other wiring
          I haven't PID tune sensors, since I can't heat my tool.
          I can try this with PT100, but customer prefers TC for some wicked reason.
          I need to use TC for this project but I also have PT100's.
          TC is Slice engineering one, PT100's are E3D.
          I have two original Duet3D TC boards (1.1) and one original Duet3D PT100 board.
            ov_darkness @ov_darkness
            @Phaedrux I've resettled my TC and heater and it looks like one of the heat block screws was the culprit. I'm reluctant to run the printer without it though - the heater and/or TC might come off the block during print.
            I'm now running M303 and it looks okay.
            I only have an issue now with the print bed - it faults because of expected temperature rise is too low, but I'm assuming it can be modified in config.
            Phaedruxundefined 1 Reply Last reply Reply Quote -1
              That would be solved by PID tuning the bed heater.
                @phaedrux I've made PID tuning and now everything is perfect. At least in static tests.
                When I get the rest of the parts, I'll test it in print, but looks like for now all of my issues have been resolved. Thanks! 🙂
                BTW a lot has changed since I last configured the Duet machine (about 2-3 years ago).
                The configuration has gotten much more complicated, but also very very powerful.
                I love it!
