    Not able to write a global variable to an file with echo command
    Gcode meta commands
    • Exerqtorundefined
      Exerqtor
      I'm trying to get an current global value writen to an .g file for restore purposes with an echo command.
      But either i'm getting the construct wrong, or SOMETHING, because it won't write the actual varriable.
      The macro is as following:
      ; /macros/Toggle Chamber Lights  v2.0
      ; Used to toggle build camber LEDs on / off
      ; Save the current sb_leds status
      if exists(global.sb_leds)
        if global.sb_leds = "n-off"
          ; do nothing
        elif global.sb_leds = "n-on"
          ; do nothing
        else
          echo >"/sys/lib/led/sb_leds-restore.g" "; sb_leds status value to restore"          ; create/overwrite file
          echo >>"/sys/lib/led/sb_leds-restore.g" "set global.sb_leds = {global.sb_leds}"      ; save the current sb_leds status
      ; Check if the LEDs are on or off, and act accordingly
        M98 P"/sys/lib/led/sb_leds-restore.g"                                        ; restore the sb_leds status from before they got manually turned off
        set global.sb_leds = "n-off"
        set global.sb_nozzle = "off"
      else
        set global.sb_leds    = "n-on"
        set global.sb_nozzle = "on"
      When i run that macro without global.sb_leds being either "n-off" or "n-on" it does create or rewrite /sys/lib/led/sb_leds-restore.g as expected, BUT it dosn't input the current global.sb_leds value. It just returns the exact line as stated in the echo command:
      Is this the intended behaviour, or have i stumbled upon a bug?
      RRF / DWC 3.4.2rc1
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @Exerqtor
        @exerqtor
        Ok, i've gotten somewhat closer to the result i want. But still not there.
        For instance if global.sb_leds = "ready" when i run the command, i want the line written to /sys/lib/led/sb_leds-status.g to be: set global.sb_leds = "ready".
        What i've achived so far is to get ready, but it leaves out the quotation marks and it writes set global.sb_leds = ready.
        The code i run to yield the results mentioned above:
            ; do nothing
            ; do nothing
          else
            echo >>"/sys/lib/led/sb_leds-restore.g" "set global.sb_leds = "^global.sb_leds^""    ; save the current sb_leds status
        else
        OwenDundefined 1 Reply Last reply Reply Quote 0
        • OwenDundefined
          OwenD @Exerqtor
          @exerqtor
          You have to quote the quotes 😀
          The best way to check is with echo in the console
          Try this
          echo "test " ^  """"^{global.myGlobal}^""""
          Then extend to
          echo >> "filename" "test " ^  """"^{global.MyGlobal}^""""
          Exerqtorundefined 1 Reply Last reply Reply Quote 1
          • Exerqtorundefined
            Exerqtor @OwenD
            @owend said in Not able to write a global variable to an file with echo command:
            @exerqtor
            Try this
            Then extend to
            I feel like i've tried every possible variant of that too. It throws an error about expecting an expression each time! If you have an idea on exactly how that codeline should look please enligthen me!
            • OwenDundefined
              OwenD @Exerqtor
              @exerqtor
              echo >>"/sys/lib/led/sb_leds-restore.g" "set global.sb_leds ="^ """"^{global.sb_leds}^""""
              • Exerqtorundefined
                Exerqtor @OwenD
                @owend
                Yeah that sure worked! Looks corny with all those quotation marks. But what, ever it worked😁
                • Exerqtorundefined Exerqtor marked this topic as a question
                • Exerqtorundefined Exerqtor has marked this topic as solved
