    Paneldue v3 7 inch no touch.
    PanelDue
    599
    • zBeebleundefined
      zBeeble
      So... rewind to a few days ago. After not using my printer for about a year, I started getting ready for some upgrades to the printer and got everything set up.
      When I turned on the printer, the touch screen had it's interface up, but no touches worked. I fiddled with things... I think I managed to erase it. That's OK.
      After some help from the forums, and a bunch of diagnostics, I upgraded the duet2-wifi from 1.20 to 3.4.1. All good. Web is responsive ... and while the new config.g needs refinement, each of the axis move in the right directions.
      Then I read that I needed to flash the paneldue --- I successfully uploaded 3.4.1 to it --- and it verified. Now the screen shows "press dot" ... with a dot. But I can't press anything.
      Is this a common problem? Is it fixable?
      infiniteloopundefined 1 Reply Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @zBeeble
        @zbeeble said in Paneldue v3 7 inch no touch.:
        Well yes: the dot. This is the procedure to calibrate the touch display. So, touch the dot 👆
        zBeebleundefined 1 Reply Last reply Reply Quote 0
        • zBeebleundefined
          zBeeble @infiniteloop
          @infiniteloop As I just tried to tell you, touching the dot does nothing. Before the upgrade and reflash, touch seemed to be broken. It also seems to be broken after the upgrade. Also upside down, but I assume that's a setting.
            @zbeeble
            But maybe pressing the screen - before the update - did something? I'm sorry, but I have no idea how to fix that 😢
            • zBeebleundefined
              @infiniteloop Yeah... I was kinda hoping that someone from the company or support team could comment --- looking for diagnostic.
              tinkerundefined 1 Reply Last reply Reply Quote 0
              • tinkerundefined
                tinker @zBeeble
                @zbeeble You may have flashed the wrong firmware onto the panel. Do you have a genuine Panel Due or a clone? I have a clone which has v2 (or v3 , I can't remember) printed on the board but is actually a 7i and so uses firmware file ending in *-7.0i.bin.
                Again from memory, a couple of years ago, I remember that I tried a few firmware files and was always able to recover using the BOSSA programmer, so no harm done flashing the wrong file. I know one displayed correctly but touch did not work. Another displayed colors wrong and was upside down (and could not be flipped in settings).
                Try to figure out if you have a clone? If you can't then post pics of front and back of board and I'm sure someone here can help.
                Duet 2 Maestro + Driver Expansion, Forklift CoreXY printer, M3D QuadFusion print head
                zBeebleundefined 2 Replies Last reply Reply Quote 0
                • zBeebleundefined
                  zBeeble @tinker
                  @tinker That wouldn't explain it's state when I first powered it up, tho --- it also didn't have touch working. I will try the 7i firmware, however, and take some pictures.
                  • zBeebleundefined
                    zBeeble @tinker
                    @tinker OK. Loading the 'c' version just gave me a black screen. re-loading the non-c version gives me:
                    https://nextcloud.towernet.ca/s/Rm6HpWQAoHjiTcZ
                    again, pressing the spot does nothing.
                    Here are the other images of the unit:
                    https://nextcloud.towernet.ca/s/rT7fAEoNGQNdRT2
                    https://nextcloud.towernet.ca/s/GSqedFSKTe3yaHN
                    https://nextcloud.towernet.ca/s/GFtSmyMgtjiojN9
                    https://nextcloud.towernet.ca/s/TQoSnWfa5MoEzYB
                    ... it's clearly a v3 daughterboard, but I don't see any telling markings on the display.
                    • zBeebleundefined
                      zBeeble @zBeeble
                      @zbeeble The touch portion of the screen seems to be attached with a separate set of mylar wires. I deoxit'ed them and reseated them. I also cleaned the screen surface with a bit of glasses cleaner --- but nothing. Still no touch.
                        Sounds like the digitizer on the screen portion has failed.
                        If you've seated all the connectors and wires correctly and it's still not working it's likely the screen itself. I'm not sure if that's something fixable or not. At least the Duet interface portion is still working correctly as the interface comes up and it takes a flash.
                        I'll see if there is anything that could be done to solve the digitizer not working, but if not, the screens themselves are commonly available parts.
                        • zBeebleundefined
                          zBeeble @Phaedrux
                          @phaedrux Thanks. ideally trying to avoid buying a new screen, but I suppose it is what it is.
                          • tinkerundefined
                            tinker @zBeeble
                            @zbeeble Sorry I missed the second comment when you said touch was not working before flashing.
                            • tinkerundefined
                              tinker @zBeeble
                              @zbeeble Filastruder sells the PanelDue 5i/7i Touchscreen Glass only for $20.
                              zBeebleundefined 1 Reply Last reply Reply Quote 1
                              • zBeebleundefined
                                zBeeble @tinker
                                @tinker Can I get the full URL for that?
                                  dc42 administrators @zBeeble
                                  @zbeeble the Filastruder touch membranes for the 5i and 7i, see https://www.filastruder.com/collections/electronics/products/paneldue-5i-7i-touchscreen-glass-only. Maybe one of these would fit https://www.aliexpress.com/item/1005002839824226.html or one of these https://www.buydisplay.com/accessory/touch-panel (make sure you select a resistive one).
                                  • zBeebleundefined
                                    zBeeble @dc42
                                    @dc42 Thanks. Sigh. But you see. deminimis (the amount at which you pay duty) is $20 Canadian. This is about $18 USD. I will be charged $20 for the privilege of duty being figured out by the post. so I will pay $20 USD for the item, $21 USD for the tax, $20 CAD for duty and $3 CAD (roughly) for tax.
                                    ... so in CAD, that's 24 + 25 + 20 + 3 = $72
                                    ... and the Canadian retailer is selling some seemingly authentic (not the Israeli company) 7i panels (a slight upgrade) for about the same money ... and I get it in a day or two. and I can still think about repairing this panel some day, if that possibility appears.
