    M556 parameters?
    613
    • Kulitorumundefined
      Kulitorum
      What are the parameters for M556? - I can only find one description and I fail to understand it.
      I have a machine that's skewed. If I move 4900mm on the X-Axis, the Y is off by 23mm.
      So I tried M556 S4900 X23 P1 ( to make it compensate on the Y-axis? - the P parameter is really never explained)
      But it does not go as expected - no real difference.
      Some documentation says that the X parameter is in Tangent, others in mm (maybe)
      Can you help me understand the parameters?
      Thank you.
      infiniteloopundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • infiniteloopundefined
        infiniteloop @Kulitorum
        @kulitorum You mean this here: M556: Axis skew compensation. That's the ultimative reference, regardless of what others say.
        Well yes, it is.
        BTW: if your Y is 23 mm off (over 4900 mm - is that true?), you really should adjust your frame.
        EDIT: Did you read this: Orthogonal axis compensation with M556?
        Kulitorumundefined 1 Reply Last reply Reply Quote 1
          Kulitorum @infiniteloop
          @infiniteloop Thanks for the help - yes, I read it all.
          You think the P parameter is explained? - Pnnn means what? Is P2 an option?
          Yes, it's 23mm over 4900mm I will fix the frame, but right now I have half a house printed and the printer no longer aligns with the print for some unknown reason 🙂
          It gets better with M556 S100 X-1 P1 and even better with X-1.9 but X-2 throws it way off. I don't get it.
          Also the documentation only referes to using the printed test piece, which really does not apply for 12x20m long houses - it does not really explain how it works.
          I hope @DC42 will try to explain tomorrow, and maybe update the documentation for others to read later.
          Thank again.
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
            @kulitorum
            the documentation only refers to using the printed test piece, which really does not apply for 12x20m long houses
            So true! Sorry that I could not imagine such dimensions.
            From the documentation:
            Apply XY compensation to Y axis instead of X
            To me, this looks like a flag which, if set (to 1), applies the counter-skew to Y instead of the default X.
            It gets better with M556 S100 X-1 P1 and even better with X-1.9 but X2 throws it way off.
            Did you mean X2 or X-2?
            Kulitorumundefined 1 Reply Last reply Reply Quote 0
              @infiniteloop X-2 of cause 🙂
                @kulitorum
                X-2
                That’s really weird. In what way does this „throw it off“? Another thing to note is the S value: according to the documentation,
                The S parameter is the length of a triangle along each axis in mm.
                Printing a house, 100 mm are way off - try 4900 instead. But I have to admit that my approach is speculative: being unable to apply the calibration tool as described in the above link, I'm left with pure guessing …
                Sorry, but time for an expert to chime in. @Phaedrux, do you know who could help with this?
                  dc42 administrators @Kulitorum
                  @kulitorum said in M556 parameters?:
                  That should work. The X parameter divided by the S parameter is the tangent of the difference between the the actual XY angle and 90 degrees. P0 (the default) causes any skew between X and Y to be compensated by adjusting the X coordinate by Y * tanXY; whereas P1 causes the XY skew to be compensated by adjusting the Y coordinate by X * tanXY.
                  If you go to the Object Model Browser in DWC and expand move->compensation->skew you can see the tangents that have been set.
                  The S parameter in M556 must be at least 10 but there are no limits on the values of the other parameters.
                  [Edit: I have made some corrections to the above since I first posted it.]
                  dc42undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @dc42
                    PS - I tried entering your original command:
                    M556 S4900 X23 P1
                    and the object model shows this:
                    which looks correct to me.
                      Kulitorum @dc42
                      @dc42 Agreed, it just does not seem to make any difference on site. That being said, the printer is in Saudi Arabia and I'm in Denmark, so I do not have hands on myself. We already have people on site and are sending another guy down there to help debug it.
                      Thank you for the input.
                        @kulitorum which firmware version are you using?
                        Kulitorumundefined 2 Replies Last reply Reply Quote 0
                          Kulitorum @dc42
                          @dc42 On most machines we are running Release 3.3 - never machines are 3.4.1
                            droftarts administrators @dc42
                            @dc42 I’ll add what you have written in your post to the appropriate pages, for a clearer description of function.
                              Kulitorum @dc42
                              @dc42 Cool, it works now - dont know why it didnt before, but now it does. Thank you for the help.
